Performancelifts.com
Discussion in 'Suspension' started by zachzap361, Mar 24, 2020.
  1. Mar 24, 2020 at 7:15 AM
    zachzap361
    zachzap361 [OP] MEAN GREEN MACHINE
    Zach
    San Antonio
    2010 Green Tundra CrewMax
    Toytec Aluma 2.5 Coilovers and Toytec rear shocks, Method NV 17", Nitto Ridge Grappler 35", RCI Skid Plate, Dirtydeeds Dual Dumped Exhaust, Volant Cold Air Intake and Throttle Body Spacer, SDHQ Ditch Mount Brackets, Rigid Blackout Spot Lights, Stampede Fender Flares, N-Fab Nerf Bars, Morimoto Fog Lights, 55 watt HID's, AJT Design Climate Knobs, Ellis Precision Shift Knob, Coverking Seat Covers, Husky Floor Liner's,Demello Off-road Bumper, Rigid and Baja Designs Lights, Jomax ABS Sensor covers
    Hey guys just needing some help.
    I plan on getting an Icon Stage 1 kit for my 2010 (really wanted fox 2.5 but they don't come in a kit like the Icon's or at least that I can find) and saw the kit on this website and it's a pretty good price but didn't know if anyone has any past experience or knowledge on this website.
    Any and all info would be helpful.
  2. Mar 24, 2020 at 7:20 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    I have read that folks have had issues with the Icon shocks- leaking, not lasting, rust.....several posts here. Do a search of icon shock and then icon suspension and you should get all the information you ever wanted to read.
  3. Mar 24, 2020 at 7:39 AM
    zachzap361
    Zach
    San Antonio
    Yea like I said I would like fox shocks over the Icon's but the Icon's 1. go to 3.5 if maxed out and 2. they come as a stage 1 kit where fox doesnt.
  4. Mar 24, 2020 at 7:39 AM
    zachzap361
    Zach
    San Antonio
    But more so it was about the website itself it they were reliable.
  5. Mar 24, 2020 at 7:41 AM
    TXTundra2722
    2015 Black Tundra
    All shocks end up leaking and the main ones, including icons can be rebuilt.... most of those kits are less than$50 a shock
  6. Mar 24, 2020 at 7:44 AM
    zachzap361
    Zach
    San Antonio
    I mean I dont plan on going to Sonora or MOAB anytime soon if ever being a Texas boy and all but I do want to upgrade my stock shocks and improve my ride.
  7. Mar 24, 2020 at 7:51 AM
    TXTundra2722
    2015 Black Tundra
    Agreed, I'm in TX as well. I've read a thread or two about the Icon's leaking, but I've never read anything about them rusting. Kings and Fox are known to rust or the finish change on them, but like I mentioned earlier all of these leak eventually and need the seals changed. I'd be willing to bet that the ones reporting the leaks probably just needed to have their shocks charged up. Either way good luck with whichever kit or shocks you go with.
  8. Mar 24, 2020 at 8:17 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Go fox. Like others I’ve heard complaints rough ride, leaky shocks etc.
  9. Mar 24, 2020 at 8:20 AM
    xtyfighterx
    Ty
    North Idaho
    My fox 2.5s can go to 4” all day. If you want a kit just piece together yourself. Would actually be better that way you can get what you want.icon sells everything separate if you like their UCAs or leaf packs etc
  10. Mar 24, 2020 at 8:02 PM
    zachzap361
    Zach
    San Antonio
    I was dead set on Fox for almost a year now but started changing my mind slowly or being open to other companies like Toytec and Icon. @xtyfighterx can you really go above 2.5 of lift with Fox? I thought MAX on them was 2.5? and if so how did you do that?
    Personally wanted to do Fox 2.5 all the way around but basic with no DCS or anything, run coach builder shackles in the rear and eventually upgrade the UCA to total chaos, Icon, or Camburg and call it a day.
  11. Mar 24, 2020 at 8:06 PM
    xtyfighterx
    Ty
    North Idaho
    2.5 of referring to the body diameter not the height....out of the box I was at 4” I have like 3 threads showing almost no preload I’m sitting dead center at 3” up front. I had to lower them almost all all the way to get to 3”
  12. Mar 24, 2020 at 8:07 PM
    TXTundra2722
    2015 Black Tundra
    You can go higher on all of them, but if you go above 3 inches you're adding way too much preload. I think if your 2wd then you can safely add just a touch more then 3 inches because you have less weight on the front... but that's more of a guess on my part.
  13. Mar 24, 2020 at 8:09 PM
    zachzap361
    Zach
    San Antonio
    Yea 4x4 here and really just want to be a good kit that will last me a long time and can have a little fun with on the weekend with the family.
  14. Mar 24, 2020 at 8:10 PM
    zachzap361
    Zach
    San Antonio
    Also wanting to fit Method NV's at 17" with as much of a offset as possible.
  15. Mar 24, 2020 at 8:12 PM
    TXTundra2722
    2015 Black Tundra
    What spring came on your kit because you seriously have a unicorn there. Nice truck
    :hattip:
  16. Mar 24, 2020 at 8:21 PM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    I have Icons for about 2 years and no issues here. I’ve done business with performance lifts. Bought a complete CST spindle setup from them. They also have good pricing on items
  17. Mar 24, 2020 at 9:55 PM
    xtyfighterx
    Ty
    North Idaho
    Should be a 700lb spring. They are the extended versions I believe there a bunch of different models I didn’t know about
    TXTundra2722[QUOTED] likes this.
  18. Jul 14, 2020 at 9:42 PM
    celicacy
    celicacy New Member
    Cy
    Jacksonville, FL
    2014 Tundra Crewmax
    Icon 2.5 Coilovers, Icon UCA, Katzkin Leather, LED Headlight, Nitto Ridge Grappler 305/55/20, Fuel Wheels, Trd Rear Sway bar
    Following. Im also about to order some icons.
