Performance & Reliability modifications
Discussion in '2.5 Gen Tundras (2014-2021)' started by DBP3, May 4, 2025 at 10:47 AM.
  1. May 4, 2025 at 10:47 AM
    DBP3
    DBP3 [OP] Who’sRandy
    Wednesday
    2014 SR5 TSS
    First time tundra owner 2014 SR5 4x4. beyond routine maintenance, what modifications have yall made that gave you the most success in increasing reliability and overall performance of the engine and truck in general? Thank you guys! Glad I found this forum.
  2. May 4, 2025 at 10:56 AM
    dherring256
    dherring256 New(ish) Member
    2018 MGM SR5
    Fuzzy Dice
    I wouldn’t put too much thought into reliability. These 5.7s are known to regularly go 500k miles and above. There are a couple of 1,000k mile tundras reported too. Just stay on top of your maintenance and you’ll be fine in the reliability department.
  3. May 4, 2025 at 11:07 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Maybe I am misreading the question but those two goals are usually on the opposite ends of the spectrum IMO. Toyota tends to overbuild their vehicles and Tundra is not exception with a few hitting a million miles. Stock set up is pretty robust.
    Long tube headers, AKA LTHs, came up in the supercharger thread but a stock truck isn't running into the same issues as a boosted truck. With that said LTHs is probably the only performance option that isn't sacrificing reliability. I've not seen evidence intakes (and filters) do anything for these trucks except at higher RPMs and WOT. All that to say I don't think Toyota left much if anything on the table for a stock NA truck.
    nobodyintexas and Mdl like this.
  4. May 4, 2025 at 11:10 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    And doing atf changes every 30-60k.
    Saltyhero13 likes this.
  5. May 4, 2025 at 11:20 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Agree
    putting reliability and performance in same sentence is like crossing the beams in ghostbusters
    Mdl and Saltyhero13[QUOTED] like this.
  6. May 4, 2025 at 11:27 AM
    Saltyhero13
    And engine oil every ~5000 miles min.
    Mdl[QUOTED] likes this.
