Performance problems after cold air intake install
Discussion in 'Performance and Tuning' started by odaflo, May 30, 2021.
  1. May 30, 2021 at 7:45 AM
    odaflo
    odaflo [OP] New Member
    Deltona
    2019 Tundra XP FLEX FUEL
    Hi guys
    Im experiencing performance issues after installing a cold air intake on my 2019 Tundra. Its been about 2 months, and now its starting to show warning lights (too rich bank 1&2) P0172 and P0175. also has a lil rough idle...... and when I floor it, it starts shaking and trembling and wont accelerate or change gear. but when I dont floor it, it runs good and changes gears like normal. I was told that with cold air intakes, I have to have the computer programmed to accept new changes...anyone else has experience with this or can confirm this? should I just go back to stock air box and forget it?....Ive seen where people have them and I assume they work just fine...im just wondering why mine is acting up. Also may be MAP sensor, Im trying to find and clean that...already cleaned MAF sensor....Please advise
  2. May 30, 2021 at 7:49 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Which intake did you get?
    In reality, intakes don't really do much except look cool in the engine bay.
    I'd go back to stock. If you want to keep it, go through and make sure all your connectors and fittings are tight.
    tttrdpro likes this.
  3. May 30, 2021 at 9:59 AM
    odaflo
    Deltona
    Ok it was a bad MAF sensor. I replaced and cleared codes...no more issues...case closed...thanks!!
    snivilous and Leo's first like this.
  4. May 30, 2021 at 10:00 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Did you install one with an oiled filter? If so, that is what damaged the MAF sensor.
  5. May 30, 2021 at 10:02 AM
    odaflo
    Deltona
    Yes I did...but can I run it dry? and what about other car make and models...dont they have MAF sensors that can also sustain damage of the same?
  6. May 30, 2021 at 10:05 AM
    Danman34
    Danman34 New Member
    Danny
    No. Oiled filters have to be oiled to filter properly. Get a dry filter. Plain and simple. Oiled filters are junk and are notorious for damaging MAF sensors, especially on vehicles like ours where the MAF is so close to the filter. No MAF sensor is designed to function with contaminants on it. Oiled filters kill them, as you’ve found out. No auto maker puts oiled filters on their vehicles.
  7. May 30, 2021 at 10:11 AM
    odaflo
    Deltona
    Good info...thanks a million...May The Lord Bless you in abundance!!!!
    RoniusMaximus likes this.
  8. Apr 9, 2023 at 3:35 PM
    powelltundra
    powelltundra New Member
    Thanks for this info. I have a 2015 1794 and thinking about installing a cool air intake system. Now that you got to the bottom of your issue, would u recommend getting one or just keeping the stock?
  9. Apr 9, 2023 at 4:13 PM
    centex
    centex New Member
    Never understood why people have issues with oiled filters. Been running them on various makes and models for over 20yrs with zero issues.
    Tundra Dude 45 and reywcms like this.
  10. Apr 9, 2023 at 5:11 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Exactly. People over oil or don’t let it soak etc
