Performance chip for 1st gens?
Discussion in 'Performance and Tuning' started by jacklduffy, Sep 21, 2018.
  1. Sep 21, 2018 at 4:12 PM
    jacklduffy
    jacklduffy [OP] New Member
    Jack
    05 Tundra Limited Crewcab Phantom Gray 4x4
    K&N air filter, Flowmaster
    Any suggestions on a performance chip for these first gens? I don’t want anything too serious but I’ve heard a lot of talk about a little more horse and a little better mileage, any thoughts?
  2. Sep 21, 2018 at 8:52 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    There isn't any really. There is Unichip but it doesn't give enough power for the cost if your truck isnt supercharged. I have it, got it on sale long ago and it's okay but I wouldn't suggest paying full price for it.
  3. Sep 21, 2018 at 9:00 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I've learned chips on a gas motor are about worthless. Tits on a bull, screen door on a submarine, me after 12 one packs of beer(I stole that from someone on here). They just cant do what a real tune will do with significant upgrades. They prey on the weak to make money. Just like the "electric superchargers" that flooded Ebay in the early 2000's. Don't waste your money.
    TundraLuv and Black Wolf like this.
  4. Sep 21, 2018 at 9:18 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Unichip has a place in the first gen market. If you have the time to tune it. And have their tuning software in theory you could make a little power with it. I’ve seen mixed results with their canned tunes. Although it was all seen in reading posts for the past 15 years. So I’m only regertitating what I’ve read and have never tested myself.
    If you have the time to really dial it in, it’s worth a shot.
    But, what I’ve found to work really well is upgraded injectors. They really make bottom end way more responsive. You will absolutely notice a difference.
    Also, bypass the coolant leading to your throttle body. Just make sure to put it back if you live in a cold climate in the winter.
    Also, feel feee to give a call with any questions. My cell is listed on my site.
    http://dirtydeedsindustries.com/product/fuel-injectors/
    Darkness, Black Wolf and ColoradoTJ like this.
  5. Sep 21, 2018 at 9:45 PM
    Great recommendation Keith! The 300.00 is for the set right?
  6. Sep 21, 2018 at 9:49 PM
    dirtydeeds
    Keith
    USA
    Yessir. $300 firbthe entire set of 8
    ColoradoTJ likes this.
  7. Sep 21, 2018 at 9:54 PM
    Jesus man, that's a great price for performance gains. Good to know.
  8. Sep 22, 2018 at 6:06 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Wait, $300 for 8 fuel injectors? And upgraded ones at that? That's a helluva deal.
  9. Sep 22, 2018 at 6:56 AM
    jacklduffy
    Jack
    That sounds like a good plan, I’ll hafta look into that more thanks!
    dirtydeeds likes this.
  10. Sep 22, 2018 at 7:42 AM
    dirtydeeds
    Keith
    USA
    Yessir. 12 hole instead of stock 4 hole. And they’re all flow balanced.
    Black Wolf likes this.
  11. Sep 22, 2018 at 7:42 AM
    dirtydeeds
    Keith
    USA
    They drop right in.
  12. Sep 22, 2018 at 8:16 AM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    @dirtydeeds can you please explain your premise on how a different injector will add performance?
  13. Sep 22, 2018 at 8:56 AM
    dirtydeeds
    Keith
    USA
    The stock 4 hole injectors are more of a squirt of fuel. Where the 12 hole injectors that we make are a fine mist of fuel
    The fuel needs to convert to vapor before it can burn in the combustion chamber.
    By being more finely atomized before even reaching the combustion chamber you get a ‘head start’ in vaporizing.
    More of the fuel vaporizes. Less is needed. You’re stepping on the gas less to propel the truck forward. It drives nicer. And uses less gas.
  14. Sep 22, 2018 at 12:32 PM
    jacklduffy
    Jack
    I do have one question, what makes yours so much better than other 12 hole injectors found from other companies?
  15. Sep 22, 2018 at 4:11 PM
    jacklduffy
    Jack
    Just curious?
  16. Sep 22, 2018 at 6:58 PM
    the_midwesterner
    Luis
    None, yet....
    I don’t disagree that better atomization helps efficiency in combustion, but going as far as using less gas is a bold stretch. You’re effectively saying that 12 hole injectors defy physics because they use less gas to be stoich. Stoich is stoich, and the 14.7:1 stands regardless of how fuel vaporizes. Atomization is the efficiency of how it burns, not that you need less to burn.
    For the 1st gen guys, the advantages they will see is the benefits of a new injector that probably isn’t gummed up and flows better. However, going to a 12 hole, which is smaller, could potentially cause issues for the older vehicles that may have some debris in the fuel system since the hole is smaller. Ragrdless, unless you are actually changing the size of the injector, it won’t be any significant gains to justify the $300 cost, in my opinion. If you are changing the fuel injector size, when the truck starts up, it will run like shit while it’s fuel washing the cylinder walls, until the O2s heat up and then feedback to the ECM and it starts pulling pulsewidth on the injectors to get it back to stoich. This is assuming the size of the injector isn’t too big that the ecu can’t compensate for it.
    For the guys considering an injector change, you’re better off just pulling your injectors, sending them off to get cleaned and flow balanced ~$75-$100, then replacing your upstream O2s for the money.
  17. Sep 22, 2018 at 7:35 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Wow. That's a lot of good info. Buuuut you did spell regardless wrong so I don't know if it's good info. :D
    Casper421 likes this.
  18. Sep 23, 2018 at 9:23 AM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    I’m telling my therapist your my biggest enabler
