Pedal Commander: Tell me Pros & Cons
Discussion in 'Performance and Tuning' started by MedicRN, Nov 15, 2020.
  1. Nov 15, 2020 at 11:39 PM
    MedicRN
    MedicRN [OP] You can't fix stupid... but you can sedate it.
    2014 5.7L V8 SR5 CrewMax 4x4
    With holiday specials around the corner or possibly at its current high for Black Friday, I am trying to weigh the pros and cons of getting a Pedal Commander.
    I have done some research but would like to hear real world experience or general info about this.
    Would/Did you buy a Pedal Commander? Why?
  2. Nov 16, 2020 at 3:38 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I don't have one because I'm not an aggressive driver. But if you want to max out your "get up and GO" then you ought to get one. I believe the only con is decreased gas mileage.
    Rica25 and MedicRN[OP] like this.
  3. Nov 16, 2020 at 3:47 AM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    4 modes with 8 setting each, a great addition to my truck. Economy mode to snap your head right off. Easy in and out, no warranty issues ,there is no reason not to have it.
  4. Nov 16, 2020 at 4:03 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I have one. It greatly improves throttle response. There is no downside for me on gas mileage. It is NOT a tuning tool. I hated the meeehhhhh sluggish accelerator pedal. The Pedal Commander fixed that.
    Get one. Have fun with it. Then add a TRD rear sway bar if you haven't already. Then drive through the miles of smiles!!!!!
  5. Nov 16, 2020 at 4:22 AM
    MedicRN
    I occasionally pull trailers and equipment. Thought it might be a good addition to tow haul mode.
    Rica25 likes this.
  6. Nov 16, 2020 at 4:27 AM
    MedicRN
    I have a couple light off-road trips I think it might be fun for. Beach and desert rock road type stuff.
    Do you think the economy mode keeps you from being too lead footed?
    Rica25 likes this.
  7. Nov 16, 2020 at 5:08 AM
    1rebmem
    1rebmem New Member
    Jef
    TN
    2018 SR5 4x4 Inherited from my dear dad RIP 4/21/2020
    Two years old and 5200 miles when I took ownership
    I too am thinking of buy one for my Tundra.
    My only hesitation is because The Tundra is my other vehicle and I don't drive it much.
    From my reading on the PC it is a huge hit with very little if any unhappy buyers.
    Any cons out there?
  8. Nov 16, 2020 at 5:23 AM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    It scared my Wife when she drove it so she won't drive it now. :burnrubber:
    Pro or Con, your call.
    Gunship Guy, WFD473, Rica25 and 3 others like this.
  9. Nov 16, 2020 at 5:30 AM
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    I am also tempted by the pedal commander, but I did read (unfortunately I don't remember where) of some having problems with engine light illuminating after installing.
  10. Nov 16, 2020 at 5:36 AM
    timsp8
    NY
    No engine light for me.
    Toyota changed the throttle response some time in the last few years, probably for better gas mileage or something. My 2010 was much more responsive than my 2018. Try to check which year it changed. You might not get much benefit in a 2014.
  11. Nov 16, 2020 at 5:42 AM
    MedicRN
    Couldn’t you just turn up the responsiveness? Also I definitely notice the change in tow/haul. So I think there is room for improvement.
    Too bad you can’t recall. I saw that happening on some OBD2 gauges as well. It may be worth digging into that but I feel like on the forums it would be talked about more if it was a consistent issue.
    Rica25 likes this.
  12. Nov 16, 2020 at 6:25 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Why spend money when the Tow/Haul button has the same effect?
  13. Nov 16, 2020 at 6:55 AM
    akmerle
    akmerle New Member
    Wasilla, AK
    2018 Tundra Platinum & 2024 GX550 OT
    While to totally agree that tow/haul makes the truck more responsive, it is very different in that tow/haul changes your shift points / holds gears longer and basically locks you out of overdrive.
    Pedal Commander keeps stock shifts points, just increases throttle input signal earlier in pedal travel.
    I have one on my Tundra and my 4R. Have had zero issues, and love that I can control both from the same app on my phone.
    The only thing I would list as a “con” would be that if you do any driving on snow / ice, the increased responsiveness will spin the tires easier. I have to turn mine off basically November - April (#alaskaproblems).
  14. Nov 16, 2020 at 7:19 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I thought S4 locked you out of overdrive. Just another example of how badly written the owner's manual for these trucks is.
    Saltyhero13 and Rica25 like this.
  15. Nov 16, 2020 at 7:20 AM
    aussieaarons
    aussieaarons die with memories, not dreams
    2019 Cavalry Blue TRD
    2” level, roof mount DVD, interior LED bulbs, sumosprings out back, OEM folding cover, Blackout emblems
    I was disappointed in the tundra driving experience until I put one in, now it has the get up and go I think it should have always had. My wife doesn’t like the “throw back in her chair” feeling so turns it off when she drives but that’s the great thing about it, can be turned in and off as you please
    Saltyhero13, Rica25 and MedicRN[OP] like this.
  16. Nov 16, 2020 at 7:46 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    PROs:
    • Improved throttle response
    • Good level of calibration adjustments with 4 modes (Econ, City, Sport, and Sport+) with 9 levels each (0 up to +/-4 each mode)
    • Can be removed without detection/Easy to install
    • Will not affect warranty
    CONs:
    • Some folks have reported glitches, the worst of the issues will trigger limp mode.
    • Pricey
    Do your research, there are other throttle boosters that may offer similar benefits with different features (Sprint Booster is one of them). I have PC and have been happy with it on Sport (-4). So far no glitches but I'm not driving much these days. Most of the glitches seem to be related to changing settings on the fly while actual driving (which they say not to do in the manual).
    I recommend take a look at the manual, it has some good charts showing how the various modes affect the throttle response.
    As far as ECON mode, if you are getting this device to save gas I think you are better off looking at and modifying your driving behavior. PC claims up to 20% fuel gains but they don't state the conditions for such gains.
  17. Nov 16, 2020 at 8:34 AM
    maxdriver
    maxdriver New Member
    ‘23 GRolla, sans ‘19 Tundra
    If you search for PC there are other threads with many comments about it. As mentioned one issue that I have read about more than once is "limp mode" kicking in when you make changes on the fly.
    MedicRN[OP] and CaptainGrumpus like this.
  18. Nov 16, 2020 at 8:53 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I bought one and had the surging issue - couldn’t be happier with the Customer service.......Larry was awesome and updated the unit remotely. Surging issue solved. I have settled on city +1 as my favorite. The throttle response on these trucks always bothered me as there is a definitive hesitation. Same with my old 4runner. Pedal commander fixes this and makes it much better to drive
  19. Nov 16, 2020 at 8:57 AM
    Saltyhero13
  20. Nov 16, 2020 at 9:44 AM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    I have a sprint booster which is the same thing except it’s very small and does not have Bluetooth. Both do the same thing. I went with the Sprint Booster because it was the first to the market and the PC is basically a copy of it. There are some documented issues with the PC where it will put your truck in limp mode at any given time.
    This video explains the possible issue with the PC and the check engine light.
    https://youtu.be/Z4S6SATkA9o
  21. Nov 16, 2020 at 10:25 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    We sell quite a few of them!!! So I know folks love them!!!
  22. Nov 16, 2020 at 10:56 AM
    My 2013 was sluggish until I got one.
  23. Nov 16, 2020 at 12:52 PM
    Hoologan
    Hoologan New Member
    California
    18 Cement Limited Crewmax TRD
    Best $250 I've spent on my truck and as a result I'm thinking about buying one for my wife's new 4runner since it is sluggish AF with the new 285s. I installed the one on my 2018 Tundra right after I did 35s and it has never driven better.
  24. Nov 16, 2020 at 1:22 PM
    MedicRN
    I doubt I will ever have the problems of ice here in Texas but useful to know of I’m out of state.
    Rica25 likes this.
  25. Nov 16, 2020 at 1:33 PM
    MedicRN
    I agree with it having a pleasant effect for smiles per gallon but there is definitely some delayed shift points. Which is great when I’m towing but around town and highway driving I don’t need/want the shift point to hang for so long. I think I like the idea of being able to get to the top of the tach and back down to the bottom without the transmission “lagging” or with a delay.
    Rica25 likes this.
  26. Nov 16, 2020 at 1:34 PM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Because it doesn't, not at all.
    PC is NOT a tuner.
    Drive by wire has ALWAYS had lag issues
    PC gets rid of the lag and you get to choose a mode that fits you best
    I had surging issues when I'd shift while in motion so I stopped doing that and haven't had any issues. I found a mode I liked for every day and haven't moved it since.
    Hoologan, Rica25 and MedicRN[OP] like this.
  27. Nov 16, 2020 at 1:36 PM
    MedicRN
    My Wife’s Lexus RX has an ECON mode she likes for highway miles. I would think maybe on long trips it could help possibly. But I think maybe if it’s just effecting throttle response it may not help with highway MPG :notsure: just a guess though.
    Rica25 likes this.
  28. Nov 16, 2020 at 1:38 PM
    MedicRN
    explain what you mean by surging when shifting. I don’t think I understand what you were experiencing.
    Rica25 likes this.
  29. Nov 16, 2020 at 1:46 PM
    rockmup
    rockmup New Member
    Todd
    I should have worded that better.
    If I changed modes while driving the truck would surge slightly while under load, really noticeable at highway speeds
    Rica25 and MedicRN[QUOTED][OP] like this.
  30. Nov 16, 2020 at 2:06 PM
    Saltyhero13
    Not sure how the RX's ECON mode works. It may or not be similar as PC. I heavily use Radar Cruise on the highway so PC is not in play for most of my long distance driving but I've noticed a slight improvement in MPG in Sport -4.
    Frankly I would test the PC ECON mode first if this is your main reason to purchase; maybe someone can lend you one to try. ECON mode is very sluggish compared to stock. If you check the document link I posted, the PC is set to "cap" (technically the PC doesn't know what the current RPMs) engine revs to 5K RPMs. You also see that the throttle response curve never intersects with the native throttle curve. Depending on your driving situation you may find the mode acceptable, for my neck of the woods the laggy response in ECON mode was unsafe for my needs.
    On another forum discussing PC one of the posters made a solid case for PC ECON mode actually hurting MPG. If I recall correctly, the gist of the argument was the Tundra's efficiency band is above ~1.2 K RPM. PC in ECON mode drags out how long you are in the sub optimal band while the other modes get you into the efficient band quickly (Pg 8 or 9 in the doc I linked). The poster could have been full of shit as I have no way to verify his numbers but it sounded convincing at face value. He also made the case that driving behavior will have the greatest impact on MPG and described what driving strategy would help increase MPGs.
