Payload
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rhernandez09, Mar 19, 2019.
  1. Mar 19, 2019 at 5:37 PM
    Rhernandez09
    Rhernandez09 [OP] New Member
    Roy
    2018 Black Tundra TSS
    i have a 2018 crewmax SR5 5.7L
    According to my load sticker I have a 1265 payload for cargo and passengers. My question is how much weight should I be comfortable throwing in the bed? I’m trying to haul a ton of gravel and trying to see How many loads I should break it down into. Thanks for any help
  2. Mar 19, 2019 at 5:42 PM
    15whtrd
    15whtrd Mr. Blonde
    Personally I would think you would want to keep it at or under 1000 pounds if it’s just you driving.
  3. Mar 19, 2019 at 5:44 PM
    Rhernandez09
    Roy
    That’s what I was think going to empty out the truck, have only a 1/4tank or so and just be me
    15whtrd[QUOTED] likes this.
  4. Mar 19, 2019 at 5:45 PM
    Beastmode1794
    Beastmode1794 Masshole
    2019 tundra 1794 edition smoked misquite
    Your beter off renting a trailer for 29 bucks at you haul do it in one trip that way you dont accedentley overload your truck gravle is heavy or ive done it with home depot buckets i forget how many you can fit but 12-14 should be fine and its easy to unload and you can do the math so at least you know how heavy it is
    Black Wolf, salmonator and 15whtrd like this.
  5. Mar 19, 2019 at 5:47 PM
    Rhernandez09
    Roy
    That’s not a bad idea
    thats not a bad idea the buckets I have plenty of those I’ll have to look into a trailer
    Beastmode1794[QUOTED] likes this.
  6. Mar 19, 2019 at 5:53 PM
    15whtrd
    15whtrd Mr. Blonde
    Yeah better than banging up the truck
  7. Mar 19, 2019 at 5:53 PM
    Beastmode1794
    Ya i think a bucket is like 80-90 lbs if i had to guess im sure you can googal it also you can go over your weight limit if your not driving far and you go slow but i wouldent go over 15-1600 total but thats just me
  8. Mar 19, 2019 at 6:06 PM
    Mnorris1206
    08 tundra
    Really why not just have a tri axel haul.it in or will it not go where you need the gravel. That's how I do my driveway .
    Other then that I would rent a dump trailor
    15whtrd and Beastmode1794 like this.
  9. Mar 19, 2019 at 6:18 PM
    Home Depot rents dump trailers.
    However, most of the time, a tandem axle end dump delivery fee is about the same.
  10. Mar 19, 2019 at 6:34 PM
    Rhernandez09
    Roy
    I only need a ton and they want to charge be double to deliver that what the rocks going to cost
    Mnorris1206[QUOTED] likes this.
  11. Mar 19, 2019 at 6:36 PM
    Rhernandez09
    Roy
    The big reason I wanted to do it my self was cause a ton of gravel isn’t o my going to cost me 30$ and they want to charge me 50$ to deliver it so I’m being stubborn basically. Was just looking to see if people have pushed they’re payload and how the truck did
    15whtrd, Mnorris1206 and ColoradoTJ like this.
  12. Mar 19, 2019 at 6:40 PM
    Take a couple loads. Should be good to go.
  13. Mar 19, 2019 at 6:44 PM
    At least you inquire about payload.
    The other day we had members bragging about 3700 lbs in the bed of their Tundras. :rolleyes:
  14. Mar 19, 2019 at 6:47 PM
    Mnorris1206
    08 tundra
    I got ya I did 3 ton last yr and it's worth it to me because the place I use knows how to spread it really good while they drive away. Less work for me!
  15. Mar 19, 2019 at 6:53 PM
    Rhernandez09
    Roy
    Yea if I was getting more I would definetly have it delivered. But I’m only doing a 6x12foot pad
  16. Mar 19, 2019 at 6:56 PM
    Rhernandez09
    Roy
    C761E9CF-D0FF-4493-9538-F0460C3C9EB0.jpg Just making this little sitting area in the front yard.
  17. Mar 19, 2019 at 7:08 PM
    Beastmode1794
    Buckets time !!!!!
    Rhernandez09[OP] likes this.
  18. Mar 19, 2019 at 7:11 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Getting it delivered and Keeping your truck from getting damaged is $50 well spent
  19. Mar 19, 2019 at 7:13 PM
    15whtrd
    15whtrd Mr. Blonde
    Looks like it’ll take about 31 full buckets.
    Watt maker and Rhernandez09[OP] like this.
  20. Mar 19, 2019 at 7:39 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Everyone knows toyota UNDERrates our payload.
    Been happening for years
  21. Mar 19, 2019 at 7:52 PM
    Beastmode1794
    31.34 to be exact so 2 trips and if its only 50 to deliver then do that for sure were i live its 100-150 delivery fee
  22. Mar 20, 2019 at 5:10 AM
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    The payload is weak on the Tundra. My wife's Highlander has more payload.
    That being said don't put gravel back there! I had the EXACT same thoughts a few years back with my '11 Tundra. Went to the yard and got several loads of gravel in the truck. It squatted pretty good but handled the load fine as long as you drove accordingly. Here's what I didn't think of: The bulldozer that loads it has a wide scoop that can control how slowly it tips the rocks into the truck but not necessarily the width etc. Rocks went bouncing off the back of my cab, sides, etc. Bottom line is I had a few scratches on the truck that I didn't have before because it's just hard to load them carefully in. It's not a dump truck. I also had a bunch of rocks stuck around the sides of the bed in the bedliner that were very difficult to get out and stuck in my back bumper. PITA.
    I learned my lesson and when I got my new truck and needed to haul a bunch of mulch I rented a dump trailer. And to be honest in hind sight on that I wish I would have just paid a little more to have a Tri-Axle just dump it on my driveway. Like you I've tried to be cheap several times.
  23. Mar 20, 2019 at 6:10 AM
    Rhernandez09
    Roy
    This is what I needed to hear a bad experience I’m sold I’ll just rent a trailer...or try to convince my wife that I need to buy a trailer so that I’m not waisting money renting them.
  24. Mar 20, 2019 at 6:21 AM
    Professional Hand Model
    Hand Protectors
    Another alternative is to purchase your rocks from the big box store. The beauty is that they are bagged and they can fork lift a pallet into your truck. Once you get home, then you take out one bag at a time and carry it to the spot vs. shovel and wheel barrow (out of truck or off of ground). The cost is about the same around here.
  25. Mar 20, 2019 at 6:24 AM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    Agreed. It is good to see someone that actually takes it into consideration, instead of the many that I see who just ignore it.
    If it were me, I would just take two trips and load the truck myself if the quarry will allow you. I have done that on a couple of occasions - just consider it my workout for the day and bring the shovel and back up to the gravel pile. The local transit mix allows you to self-load. Some places don't.
    Either that, or have them load it with a bobcat instead of a loader. Smaller bucket. Just make sure the operator is competent.
  26. Mar 20, 2019 at 6:26 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    yea? well, when i get down to your place, i'm bringing 3701lbs o' crap. just because.
  27. Mar 25, 2019 at 9:12 AM
    Rhernandez09
    Roy
    D60E6826-D122-4203-83A7-74AD781F0E4B.jpg Got it done split the load between mine and a buddies truck worked out fine.
