Paul'pod - DIY version of sPOD (Work in Progress)
Discussion in 'Lighting' started by Paulskie, Dec 13, 2015.
  1. Dec 13, 2015 at 8:41 PM
    Paulskie
    Paulskie [OP] New Member
    Paul
    2014 Attitude Black 1794
    SABM, TRD sway bar, interior LED swap, Husky's in front and WeatherTech in the back, TRD Pro Grill, Rigid Fod lights, Rigid 40" E-series, Rigid 32" hood light, BLHM with RX350/STI projectors, 4% tint, 50% windshield.
    Hey, guys.
    After owning 2014 1794 for over year, and not being able to find any additional spaces for switches except for Spod, I have decided to build my own.
    Here is my parts list (I will be editing this as build progresses)
    1. 12v Marine Boat Bus. ( gives me 6 switches with fuses) $74
    2. AGT (5 Pack) 30/40 AMP Relay Harness Spdt 12V Bosch Style (40AMP-HRNS) $14
    3. 32lf of 16AWG, 6lf of 10AWG, 6lf of 12AWG wire. $15
    4. Marine grade heat shrink, butt connectors. I chose all marine type to protect from moisture. (Some may say its an overkill, but I've been doing this for years and never failed.) $10
    5. Soldering gun and Head gun, plus misc tools and clean table.
    I plan to remove the sunglasses lid/pocket and install switches in its place. I do have to trim the Bus switch plate little bit along the top and bottom, but surprisingly side wise it fits perfect.
    So far I plan on using only 2-3 of 6 available switches.: 40" light bar, GPS On/Off, and hood Raptor mod.
    Couple hours of work got me this far today.20151213_185107.jpg 20151213_185116.jpg 20151213_185140.jpg 20151213_195155.jpg 20151213_200415.jpg 20151213_200448.jpg 20151213_202415.jpg 20151213_202556.jpg
    Berdine, Bob, MotoTundra and 3 others like this.
  2. Dec 13, 2015 at 8:51 PM
    Looking good. Very pro. I think you should go with the "Bilge Pump", "Anchor Light " "Depth Sounder", "Fresh Water", "Kontmeter", and "Bait Pump" stickers just to make it interesting. heh heh...:oldglory:
    zcarpenter92 and Paulskie[OP] like this.
  3. Dec 13, 2015 at 9:12 PM
    Paulskie
    Paul
    That thought had cross my mind. ;)
  4. Dec 14, 2015 at 5:45 AM
    TruckLife900
    TruckLife900 I'd rather B hunting
    2013 White SR5
    Looks clean :thumbsup:
  5. Dec 14, 2015 at 2:31 PM
    It's a model. I didn't catch it at first though something didn't look quite right.
  6. Dec 14, 2015 at 6:25 PM
    flynbyu2
    flynbyu2 I'm your huckleberry...
    NorCal
    2015 SR5 CrewMax 2WD
    Flowmaster Super 50 / Dual In - Dual Out Exhaust BakFlipG2 Tonneau Cover TRD Rear Sway Bar
    You could go all James Bond and label them;
    • Oil Slick
    • Smoke Screen
    • Left/Right Front Wing Machine Guns
    • Rear Bullet Proof Screen
    • Tire Slashers
    • Ejector Seat
    That's how I roll.
  7. Dec 14, 2015 at 8:57 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    That's awesome, nice work. Can't wait to see the final product!
  8. Dec 14, 2015 at 11:44 PM
    Paulskie
    Paul
    These are the only ones I had at this time:
    Cblowery21 likes this.
  9. Jun 26, 2018 at 11:47 AM
    BeachyTundra
    BeachyTundra New Member
    Brandon
    Spokane
    2017 MGM 5.7L DC, Bilstein 5100s
    Dead post revival as I am looking into doing this.
    This would in a sense, prevent you from having to run multiple wires in from your battery each time you add an accessory, correct?
  10. Jun 26, 2018 at 12:20 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Use this, no running wires into your cab
    Check this out at Amazon.com
    Blazer C3050K Wireless Management System for 12V Accessories, 1 Pack https://www.amazon.com/dp/B06XNV3PPC/ref=cm_sw_r_other_apa_hfPmBb1BFJANN
    I use it to control my relays in this
    ONLINE LED STORE 12-Slot Relay Box [6 Relays] [6 Blade Fuses] [Bosch Style Relays] [Easy Installation] [OEM Factory Look] - Fuse Relay Box for Automotive and Marine Use https://www.amazon.com/dp/B072KJNPHJ/ref=cm_sw_r_other_apa_rhPmBb96ZHMSH
    Pudge likes this.
  11. Jun 26, 2018 at 12:52 PM
    BeachyTundra
    Brandon
    Spokane
    So, I am with you on the first item. You mount that in your engine bay, and run all of your accessories to that. You then have a remote to turn on said accessories, rather than having manual switches in your cab, correct?
    You lost me on the second part. I am not incredibly familiar with electrical work, in the sense that I don't really know how to make relays work properly and in my favor. I am comfortable doing basic wiring; ie; wiring in an amplifier for a stereo, add-a-fuse type work, and always-on USB/Car Chargers. That sort of thing. Can you help explain a bit more what you mean?
    Also, on a side note, I have been throwing around the idea of adding foot-well lighting as well as rock-lights. I would like the option of having the lights turn on when unlocking the doors, opening the doors, as well as turning them on individually by way of switch. I'm guessing this sort of thing would require some sort of relay?
  12. Jun 26, 2018 at 12:59 PM
    Berdine
    Binghamton, NY
    I used the first part to control the lights, the remote makes it easy, carry into my house at night if I need to use the lights. I use this to trigger my relays.
    The 2nd part is a really holder with fuses. Wire your relays and lights and other stuff to them, it's a safer approach than just using the Blazer. That way too you can run more lights and accessories of of 1 switch if you wanted too.
    I also use a 12v fuse panel for power to my relays so they're all fused separately. Extra protection.
    For the lights to come on when you hit unlock, yes you have to find that trigger wire then tap into it, then to your relay, also depends on how much your leds draw, you might not need 1, but it's better to be safe.
  13. Jun 27, 2018 at 6:46 PM
    Paulskie
    Paul
    That was the intention of running it safe. I've seen way too many truck catch fire due to (~#$&(*$ wiring and took extra steps.
    I've switched to S-POD (price was TOO good to pass it up) and still use the system in my boat.
  14. Feb 10, 2022 at 2:48 PM
    Shadowfax1
    Shadowfax1 New Member
    San Francisco Bay Area
    2018 Toyota Tundra 1794 Edition w/ TRD Off-Road Package
    GPS on/off? What's the purpose/use case for this?
