Patch panels for bed rust?
Discussion in 'General Tundra Discussion' started by TurboGoKart, Oct 8, 2019.
  1. Oct 8, 2019 at 7:55 PM
    TurboGoKart
    TurboGoKart [OP] New Member
    While I was lifting my DC today I noticed that there are a couple decent sized holes in my bed. I was going to rip out the liner to have it Linex’d but now I need to fix the rust first lol.
    Does anyone make replacement metal or patch panels for the bed? Seems like it’s at the corners mostly. Might need to fix a brace under one of the corners.
  2. Oct 13, 2019 at 1:59 PM
    TurboGoKart
    Bump. Anyone have a suggestion short of pulling the bed off? It’s just a couple smaller holes kinda in the corners.
  3. Oct 13, 2019 at 2:16 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    Seems like the best fix I've seen is to cut out the rusted portion, clean up the rib underneath and weld in a patch from the top side. Grind your welds, prime and have your liner sprayed. That's the short version. There's a thread here somewhere about fixing it that's more detailed.
  4. Oct 13, 2019 at 2:39 PM
    TurboGoKart
    Yeah I figured that. Was just trying to see where I could buy those patch panels.
    I have a welder and all of that. Wouldn’t be the first time I’ve made mods to the body of a vehicle lol. I currently have a 93 Mazda RX7 with an LS1 from a Vette in it.
    15whtrd and Prostar 190 like this.
  5. Oct 13, 2019 at 6:00 PM
    duece292
    Greg
    Green Bay, WI
    I'm not sure if there are actual patch panels or not. From what I remember reading, I think guys were just cutting a piece of sheet metal to fit and welding it in.
    TurboGoKart[OP] likes this.
  6. Oct 13, 2019 at 6:20 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Yeah unfortunately for our Toyotas there aren't a lot (or any, really) of aftermarket patch panels like you would see in an LMC catalog for a 71 Chevy c10 or what have you.
  7. Oct 13, 2019 at 6:22 PM
    :worthless:
  8. Oct 13, 2019 at 6:37 PM
    TurboGoKart
    This was during surgery. RX7 is still “under surgery, although the motor is all mounted, rear end all mounted, etc. LS1 used to be in the Nissan 240sx on the left, went into the FD on the right. Foreground was my Rubicob Wrangler that I built.
    2D269EC4-44B4-46B8-A507-C0240AD4CE72.jpg14F852FE-B831-41CA-9DFA-C4C8C780F825.jpg C905FEA0-D636-4FC7-BBA3-F7D252A1D3CA.jpg
    Ford 8.8 rear end. Had to custom make the bracket to hold the front of that in. Fun times lol.
    15whtrd and Prostar 190[QUOTED] like this.
  9. Oct 13, 2019 at 6:39 PM
    Nice job bet that will be a wild ride.
  10. Oct 13, 2019 at 6:41 PM
    TurboGoKart
    The 240sx was a freaking blast haha. One of the more raw cars I’ve owned. Had 275 Mickey Thompson ET Streets (drag radial) and I could still kick the rear end out. Soooo much fun haha.
  11. Oct 13, 2019 at 6:42 PM
    What did the LS1 come out of?
  12. Oct 13, 2019 at 6:52 PM
    TurboGoKart
    99 C5 Vette. Gen 3. Has LS6 intake manifold, cold air intake, Texas Speed Torquer v.3 cam and valve spring kit. Had 1 3/4” headers on the 240, will go with 1 7/8” on the RX7 because I may do a D1SC blower, we’ll see.
  13. Oct 13, 2019 at 6:56 PM
    Nice! I have a LS1 in a WS6 Trans Am and an HO LY6 in my ski boat.
  14. Oct 13, 2019 at 7:05 PM
    TurboGoKart
    Haha I bet that boat is fun!
  15. Sep 2, 2020 at 6:55 PM
    takeadoe
    takeadoe New Member
    2008 Tundra Double Cab
    None
    Hey, I’m curious if you ever found any patch panels? I just had a body shop guy look at my 2008 DC and that was his first question! Mine is rusted bad enough that it is moving up the side and there would be no way to repair without hours of fabrication. I’m afraid I’m going to have to find a used bed!!
  16. Sep 2, 2020 at 6:59 PM
    TurboGoKart
    Sadly, I have not. Haven’t looked too much to be honest. My rust is all on the horizontal portion of the bed, but I’d like to kill it before it gets bad.
  17. Sep 5, 2020 at 3:50 AM
    takeadoe
    takeadoe New Member
    None
    Thanks! I just posted a plea for help!
