Passenger Tail light not working
Discussion in '3rd Gen Tundras (2022+)' started by pgillen, Aug 18, 2025.
  1. Aug 18, 2025 at 10:14 AM
    pgillen
    pgillen [OP] New Member
    Pat
    2022 Tundra Limited
    I've got a 2022 Limited Tundra and the rear passenger tail light is not working.
    I think these are not replaceable bulbs, but LED's. Is there a unique Fuse per tail light by chance?
    Any help is appreciated.
  2. Aug 19, 2025 at 7:01 AM
    joescho
    joescho New Member
    Joe
    Scranton,PA
    2024 Supersonic Red Platinum
    There's a tail light recall currently in the works. 25TA06 I'm sure the dealer would do something for you with that.
  3. Aug 19, 2025 at 7:08 AM
    75tranzam
    75tranzam New Member
    Midlothian, Va
    2024 Midnight Black 1794 Limited Edition #751
    The current recall (25TA06) is for reverse lights and the housing allowing moisture into the assembly, not tail lights.
  4. Aug 19, 2025 at 7:12 AM
    75tranzam
    Midlothian, Va
    https://youtu.be/Za_FZSOckCQ?si=tHkBgqAsNdaRzs0L
    Here's a more detailed breakdown:
    1. Access the tail light: Open the tailgate to access the tail light assembly.
    2. Remove the bolts: Locate and remove the two 10mm bolts securing the tail light to the vehicle.
    3. Detach the assembly: Gently pull the tail light assembly away from the vehicle.
    4. Disconnect wiring: Release the plastic clips holding the wire harness and disconnect the main tail light connector. If equipped with a luggage switch, disconnect it as well.
    5. Remove the bulb(s): Twist the bulb socket counterclockwise to open it and remove the old bulb(s).
    6. Install new bulb(s): Replace the old bulbs with new ones, ensuring they are properly seated in the socket.
    7. Reassemble: Reconnect the wiring harness, ensuring all connectors are securely attached.
    8. Reinstall the assembly: Align the tail light assembly and push it back into place.
    9. Secure the bolts: Tighten the two 10mm bolts to secure the tail light assembly.
    10. Test: Verify the functionality of the new bulb
