Passenger side trailer lights not working
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mr.Williams, Jul 23, 2021.
  1. Jul 23, 2021 at 10:48 AM
    Mr.Williams
    Mr.Williams [OP] New Member
    Hi,
    I have a trailer and the passenger side trailer lights do not work. Not the brake, signal, or tail lights. The lights on the truck are fine and i checked the tow tail fuse aswell which is fine. The ground wire is good at both ends. Does anyone have an idea of what it can be?
  2. Jul 23, 2021 at 11:13 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Did you check to see if the trailer light is getting power? LED or halogen bulbs?
  3. Jul 23, 2021 at 11:19 AM
    Mr.Williams
    Yes. As I indicated it’s only the passenger side which is not working. Led.
  4. Jul 23, 2021 at 11:36 AM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    Sounds like someone forgot a grommet on the trailer wire harness for the passenger side and the wire is grounding out. Also, check the trailer plug to make sure that some of the wires did not pull out of the lugs.
  5. Jul 23, 2021 at 12:57 PM
    Mr.Williams
    I did some trouble shooting and it turns out the female pin which plugs into the truck had issues, I’m gonna cut and replace it. Thanks for your help.
