Passenger side mirror fell out
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jadoti, Aug 13, 2017.
  1. Aug 13, 2017 at 12:07 PM
    Jadoti
    Jadoti [OP] New Member
    Central TX
    2017 sr5 5.7l
    Roll n lock, viper remote start, RC 6" lift, 35" Toyos, 1.25" Spidertrax adapters, Bullydog BDX tune
    I went thru a carwash and my solid as a rock 2017 tundra decided to shed some parts... Roof trim, antenna, and passenger side mirror.
    Does anyone have experience reattaching the mirror? The glass came out and was hanging by it's wires and I can't seem to "snap it back on" is there a trick to it?
  2. Aug 13, 2017 at 12:10 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Ouch. That's seven years of bad luck bro.
  3. Aug 13, 2017 at 12:17 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    Only bad if it breaks the actual mirror;)
    Law323 and Wynnded like this.
  4. Aug 13, 2017 at 12:22 PM
    TXMiamiFan
    Jose
    Don't ruin my attempt at being funny LOL
    GNTundra likes this.
  5. Aug 13, 2017 at 12:23 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    Lol sorry! I'll go to my corner :p
    CM-LENNY and GNTundra like this.
  6. Aug 13, 2017 at 12:27 PM
    TXMiamiFan
    Jose
    No need. Only the first time. Do it more times and you won't get dessert after dinner.
  7. Aug 13, 2017 at 12:29 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    Awe man.....i like dessert! I'll behave!
    TXMiamiFan[QUOTED] likes this.
  8. Aug 13, 2017 at 12:37 PM
    I never go through those for that reason...wash by hand or open slot at car wash
  9. Aug 13, 2017 at 12:37 PM
    Jadoti
    Central TX
    2017 sr5 5.7l
    Not that I know of on the antenna, and folding in the mirrors doesn't do anything since the wash pops them back and forth a couple times when running thru( they don't hold in the folded in position with any strength). Not sure what I could have done about the roof trim.
  10. Aug 13, 2017 at 12:47 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    If memory serves (famous last words...) the mirror glass should have L-shaped tabs that face downward and then it should sort of fit straight in then snap downward. My original mirrors are in storage so I can't check them directly.
  11. Aug 13, 2017 at 1:25 PM
    Jadoti
    Central TX
    2017 sr5 5.7l
    Here's the back of the mirror and inside the housing. I can see inside the housing the adjusters have hooks, I can see where they clip to the mirror, but I can't figure out how to snap them together. No matter how I set the mirror in and push there's no clicking. Couple that with the outer housing hiding everything as I put the mirror on so I can't see anything once it's up there. Doesn't look like the housing comes apart to work it from behind the mirror ....
  12. Aug 13, 2017 at 1:39 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    That sucks... I'd take it back to Toyota and talk shit .. I'm sure they'll help you out with that
  13. Aug 13, 2017 at 2:08 PM
    Your missing the metal spring clips. Just disconnect it and order the parts, on install, tilt the mirror all the way down from inside the cab. Jump out and slide the mirror frame in the slots, and use a plastic mounding removing tool to pry down on it until it pops into place. It is easy.
    The anntenna your screwed. Order a new one. Not the complete assembly, just the screw on part.
    My roof trip was blown out in one of these car washes as well. Crap design.
    NewImprovedRon and Wynnded like this.
  14. Aug 13, 2017 at 2:08 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    According to these, you set the glass in there just like you probably have been. Then the glass needs to be "slid" down on the vertical plane till it "snaps/clicks" to it's locked position. After reviewing this, it's familiar but I was doing it with mine off the truck on the carpet and also using my bare feet to hold everything. Probably not feasible while on the truck. If you can pop into a dealer and have them do it, try that I suppose. I also remember expecting to something crack and the swearing to begin....
    https://www.tundras.com/threads/diy-replace-side-view-mirror-glass.1083/
    http://shop.muthco.com/content/pdf/install/21001340.pdf
    NewImprovedRon and ColoradoTJ like this.
  15. Aug 13, 2017 at 2:10 PM
    Did yours have the little metal clips that came out? My 12' had those.
  16. Aug 13, 2017 at 2:11 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Not that I can remember....
  17. Aug 13, 2017 at 2:12 PM
    Weird. Maybe that was on my POS Dodge that always fell out.
    Wynnded[QUOTED] likes this.
  18. Aug 13, 2017 at 3:41 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Call it 3.5. Mirror didn't break, just fell off LOL
  19. Aug 13, 2017 at 8:09 PM
    Jadoti
    Central TX
    2017 sr5 5.7l
    The second link provided what I needed. The circle behind the mirror pops off and was easy to mount back on, then the mirror just snapped onto that. Didn't see anywhere that needed metal clips, it all seemed to come together fine after realizing that circle piece comes off.
    Thanks much for all the help... Still gotta go back to Toyota for the trim and should probably use this time to get a nice stubby antenna, but I feel much better having my mirror back!
