passenger side kick panel electric diagram ?
Discussion in 'Audio & Video' started by TheBeast, Mar 6, 2020.
  1. Mar 6, 2020 at 4:52 PM
    TheBeast [OP] The Beach
    finishing wiring my alpine rear view camera to alpine HU. I need to locate the ACC and reverse wires by the passenger side kick panel so I can tap into them. I see couple big plugs there. MY is 2012.
    thanks guys !
  2. Mar 6, 2020 at 5:32 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    You can use a test light to Find ACC and reverse im going to look around see if I can find a wiring schematic but I think it will be easier to check 1 wire at a time for Acc by having someone turn the key on and off and the same thing for Reverse key on and keep going from park to reverse and see which one lights up but I’m going to look will post up if I find something
    TheBeast[OP] likes this.
  3. Mar 6, 2020 at 5:34 PM
    thanks !
    I think for reverse its the 11 pins white plug and pin #3 blue color from what I found online. still looking for ACC
  4. Mar 6, 2020 at 5:39 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
  5. Mar 6, 2020 at 5:40 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    Sorry doing it from my phone according to that diagram ACC is a green wire
  6. Mar 6, 2020 at 10:24 PM
    surffj62
    surffj62 New Member
    2011 DBL RW
  7. Mar 7, 2020 at 11:26 AM
    yes same setup here. I need the reverse lead for the HU and acc/ground for the alpine camera. I will probably tap into HU for these 2. I also have the micro bypass but that is for the parking brake.
