Passenger side dash pop/ sound!
Discussion in 'General Tundra Discussion' started by JmJ1015, May 5, 2017.
  1. May 5, 2017 at 6:52 PM
    JmJ1015
    JmJ1015 [OP] New Member
    2015 silver crewmax tundra
    Hey all! New to the forum and just got a 2015 crewmax tundra... by the way love it! Only thing is i randomly hear this popping sound when driving above glovebox...its not the glovebox itself bc i took it out.... its wierd the noise will go away most of the time after like 15 min or soo of driving...... tried a lot of different things.need answers!
    Lilly likes this.
  2. May 6, 2017 at 5:07 AM
    Lilly
    Lilly New Member
    Troy
    North Carolina
    2015 White Tundra 1794 Edition
    4-6" RCD Lift System, 20" Moto Metal Rims. PIAA LED Light bar, Tonneau Cover
    Great question I too have that intermittent popping sound and cannot seem to track it down.
  3. May 6, 2017 at 6:21 AM
    JmJ1015
    It almost sound like someone is dropping tic tacs on the dash. Haha. Its.very puzzling.
  4. May 6, 2017 at 6:27 AM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    I tracked my sound to only when accelerating. Mine is on the very front of my dash where the window is framed. The column that contains the oh shit handle, at the very bottom.
    Same with you guys?
    Lilly likes this.
  5. May 6, 2017 at 6:33 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    The only thing that rattled in mine was the removable shelf inside the glovebox. I took it out and no more rattling.
  6. May 6, 2017 at 6:33 AM
    JmJ1015
    I havent pin pointed it exactly... but it does tend to happen more when accelerating and going over small road bumps. has to be something!
    Lilly and Eclipsed & Floating like this.
  7. May 6, 2017 at 6:35 AM
    JmJ1015
    Its not soo much of a rattle it is more like a tapping or poping. Or like i said earlier like someone is dropping tic tacs on top of the daah.
    BlueFalconActual likes this.
  8. May 6, 2017 at 7:26 AM
    757TUNDRA
    757TUNDRA Not a New Member
    Illinois
    2018 Barcelona Red Metallic Platinum 4x4
    OEM Bed Cover, OEM Bed Rail System, OEM Bedmat, OEM Doorsill Protectors, OEM TRD Rear Sway Bar, OEM Color Matched Door Handles, OEM Color Matched Mirror Caps, OEM Bed Net, OEM Driver Side Grab Handle, BFG K02 LT275/60/20, WeatherTech Digifit FloorLiners, Salex OCD Console Organizer, Salex Console Tray
    Others who have had this problem placed thick pieces of velcro between the dash and the lower portion of the windshield to prevent the rubbing and it took care of their noise. Others have placed thick velcro between their dash and the a-pillar and it took care of their noise. Mine makes a noise in the a-pillar (behind the handle) only when the temp is below 45 degrees. Good luck, it seems everyone's noises are a little bit different.
  9. May 6, 2017 at 7:33 AM
    JmJ1015
    Thanks for the reply 757tundra! Ill give those couple things a try...Yea i noticed mine is worse as well when it is colder out.
    Lilly likes this.
