Passenger seat- welded nut broke free
Discussion in 'General Tundra Discussion' started by Gusser10, Oct 9, 2021.
  1. Oct 9, 2021 at 6:51 PM
    Gusser10
    Gusser10 [OP] New Member
    2017 Tundra TRD Pro
    Removed passenger seat on 2017 Tundra TRD Pro to wire some audio. I was re-installing the seats and the welded nut that the seat bolt screws into seems to have broken free from the floor frame under the vehicle. Bolt is still attached loosely and now spins freely but I can’t access the nut from below the truck. Any ways around this other than a hole saw to the floor frame?
    And before you have to ask, Yes! The bolt seemed to be stuck so I tried to muscle it through which was a bonehead move. Another lesson learned but I’m still in hopes I can resolve this without too much of a mess. Thanks in advance.
  2. Oct 9, 2021 at 7:10 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    Pictures?
    2mchfun likes this.
  3. Oct 9, 2021 at 7:11 PM
    2mchfun
    Lots of options, without seeing I can't say for sure. That said I think I would try to drill a small hole next to it and fill the cavity with epoxy via a pretty big syringe type injector.
    crewmaxlmt likes this.
  4. Oct 9, 2021 at 8:11 PM
    crewmaxlmt
    scott
    That was what I was thinking as well. Use something to secure the bolt so that it could be tightened down. I just was not clear about the situation without pictures.
