Passenger Low Beam and Parking Light Out
Discussion in 'Lighting' started by jpaul017, Jan 31, 2020.
  1. Jan 31, 2020 at 5:03 AM
    jpaul017
    jpaul017 [OP] New Member
    Jeff
    2007 Tundra Limited CrewMax 4x4
    I just noticed last night that my passenger low beam and parking light were both out. First off, these look pretty difficult to get to. So, before I go replacing the bulbs is there something that would cause both of those to go out together? Everything else appears to be working. High beam, fog light, turn signal, etc. This is a 2007 Tundra Limited CrewMax. Thanks!
  2. Jan 31, 2020 at 5:57 AM
    I would change the bulbs to see what happens. If it's the parking light on the side that you are referring to, pull the headlight out to get to it. It's easy to pull the headlight, just be careful pulling the panel below it. Gently pull it straight out from the front so you dont snap the 2 pins that hold it in.
  3. Jan 31, 2020 at 4:32 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Check fuse also.
  4. Feb 12, 2020 at 4:31 AM
    jpaul017
    Jeff
    Good news is that it was just the bulbs, just happened to both be out. Bad news is that I broke the pins on the panel below. :mad:
  5. Feb 12, 2020 at 5:13 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Broke 3 out of the 4 pins on my filler plates. 3M mounting tape has been holding on strong.
  6. Feb 12, 2020 at 5:16 AM
    BrandonL812
    Brandon
    Panel should be fairly cheap to replace.
