Passenger Door Lock Switch
Discussion in '2nd Gen Tundras (2007-2013)' started by elwood427, Aug 1, 2024.
  1. Aug 1, 2024 at 6:12 PM
    elwood427
    elwood427 [OP] New Member
    2009 2WD Ltd Crewmax 229,000 miles
    Hoping someone will have answer to my goofy door lock question.
    I have a 2009 CrewMax Ltd 5.7 if it helps.
    I took my truck to the dealer to get the leaky evaporator replaced. A week later I noticed that when my son opened the passenger door, I would hear a click on my side of the truck. When he closed the door I hear two clicks. I took it by the dealer because they didn’t place the hood release cable back correctly after they reinstalled the dash.
    I asked about the door noises and they said I had a bad switch. This noise only occurs from opening or closing the passenger front door. I have seen problems with the actuators but couldn’t find anything on the switch.
    The door will lock and unlock with the driver side control button or the key fob but pass side door switch does not work.
    I pulled the cover off and disconnected the plug from the switch. I took my continuity tester and put the leads on the switch pins. It would change when I pressed the lock or unlock so does that mean the switch is good?
    I’m assuming the actuator is working and getting power since it works from the other sources.
    Is there a better way to test the door switch?
    Thanks in advance.
  2. Aug 1, 2024 at 6:31 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Make sure the cables are installed correctly, completely seated and clipped into to the handle.
  3. Aug 1, 2024 at 6:51 PM
    elwood427
    Thanks Shawn. I will double check again.
    I guess I need to also check if I am getting power on the female side of the harness. I’m not sure if there is another harness connection behind the dash that may be unplugged.
  4. Aug 2, 2024 at 6:07 AM
    Madams2014
    Madams2014 New Member
    Michael
    Black 2014 tundra 5.7l
    Buncha body damage from driving crazy
    YOU need to tell the dealership about this (if it took place after their repairs) and see if it is something they did wrong while repairing your ride.
  5. Aug 2, 2024 at 7:03 AM
    shawn474
    MoCo, Maryland
    It would take 5 minutes to take the panel off and see if everything is installed properly; personally I wouldn’t waste the time to take it back to the dealership if it’s an easy fix. If you get the panel off and see that everything is installed correctly and it still isn’t functioning properly, replace the panel and set an appointment with the dealership.
