parts compatibility gen 2.5 vs gen 3
Discussion in '2.5 Gen Tundras (2014-2021)' started by Dutch73, Mar 21, 2025.
  1. Mar 21, 2025 at 12:32 AM
    Dutch73
    Dutch73 [OP] New Member
    Richard
    ‘14 Silver 4wd LB Crew
    ‘Morning
    my 2014 is starting to show a little ware. There are a lot of factory takeoff from the third generation out there. I’ve done the research and I’m pretty sure they are compatible but not 100% sure. So my question, do the CV shafts and both front and rear struts work interchangeably between these two generations. Thank you
  2. Mar 21, 2025 at 4:58 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    I would look at the part number. If they are the same then yes.
