Part #s for splash shields behind headlights?
Discussion in '2.5 Gen Tundras (2014-2021)' started by RussellVaughan, May 6, 2021.
  1. May 6, 2021 at 10:02 AM
    RussellVaughan
    RussellVaughan [OP] New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    Anybody know the part numbers for the flexible rubber splash shields behind each headlight? I'm in the process of doing the LED conversion on my '15 and would like to replace them.
  2. May 6, 2021 at 10:59 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    go to sparksparts.com, they have a chat feature and can help you get the right part
    batman900 and RussellVaughan[OP] like this.
  3. May 6, 2021 at 11:44 AM
    RussellVaughan
    Houston
    that was super easy, thanks for the recommendation.
    for anyone else that might be interested: the part number is 53296-0C030 (Heat Shield). Same part used for both sides, so order two.
  4. Feb 15, 2024 at 6:38 PM
    FIJI8364
    FIJI8364 New Member
    Missouri
    2011 Tundra 4.6 Liter V8
    My Tundra doesn't have a heat shield (shroud) like this between the battery and headlight on driver side (left side). Is there normally two? i don't see the driver side heat shield in schematics.
