Parking Sensor Issue
Discussion in '2nd Gen Tundras (2007-2013)' started by SOB, Feb 10, 2017.
  1. Feb 10, 2017 at 6:01 PM
    SOB
    SOB [OP] Big Member
    Ohio
    2013 Red Crew Max Platinum
    Bought my 2013 CM Platinum about a month ago now. In the last couple weeks I started having an issue with the front driver's side parking sensor.
    According to the manual the front sensors do not indicate until you are under a certain speed (off the top of my head 3mph). When I am parked, but in drive or moving very slow, the sensor is on SOLID BEEP constantly. Sometimes it will blip off but turn back on.
    The sensor is clean of debris......what else should I check?? It's not easy to get to so I thought I would ask first (search didn't turn up much of anything).
    Thanks!
  2. Feb 10, 2017 at 6:02 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    I had the same issue. Drove me nuts. I would be stopped at a red light and it would beep. So I turned it off and hadn't have it on since.
    MT Madman likes this.
  3. Feb 10, 2017 at 6:04 PM
    SOB
    SOB [OP] Big Member
    Ohio
    Damn that was a fast response...
    Same here though. I also turn it off cuz it's annoying. BUT, I park in enough tight places that I need to use it and don't want to go without it!
  4. Feb 10, 2017 at 6:44 PM
    TXMiamiFan
    Jose
    LOL. We have live customer service here at Tundras.com
    ColoradoTJ likes this.
  5. Feb 10, 2017 at 7:01 PM
    14limited
    14limited Diehard Florida State fan
    Matthew
    14 limited 4wd
    3" OME magnum front bumper and steps spyder headlights MB TKO wheels
    My wife hated mine beeping when we would go through drive thrus and stuff she's glad I have it turned off since I got my magnum bumper without sensor holes
  6. Feb 10, 2017 at 7:10 PM
    Joeshaker
    Joeshaker New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    Check the retainers and the wiring harness mounting locations. If there's anything loose they can move around and give false alarms. I backed mine into a honda accord leaving discount tire. Might not have if I had them on. Got an aftermarket bumper, the body shop didn't replace the retainers and the bumper doesn't have any place to attach the harness to. Got it working with new retainers and got some weld mount things to glue onto the bumper to attach the harness to. Our trucks are badass but hard to see out of, don't be like me and shut it off then run over little cars!
  7. Feb 10, 2017 at 7:13 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    On the front you should be able to get to the back side of the sensors by taking off the Lower inner fender liners.
  8. Feb 10, 2017 at 8:47 PM
    I back my truck into everywhere I go. Annoyed me on day one. 3 years later and never turned it back on.
    geno0506 likes this.
  9. Feb 10, 2017 at 8:50 PM
    geno0506
    geno0506 New Member
    Michael
    How in the heck did people survive when they never had sensors, blind spot monitors and so on, they drove ok! lions and tigers and bears oh my!
    :crapstorm::crapstorm::crapstorm::crapstorm::crapstorm:
    maybe just get these, cheaper too
    Tundra2 and NewImprovedRon like this.
  10. Feb 11, 2017 at 4:41 AM
    SOB
    SOB [OP] Big Member
    Ohio
    I honestly didn't think I needed them when I first got the truck. Hell I have a backup camper now! But boy did I get used to them. Like mentioned above these trucks are hard to see out of. I drive downtown Cleveland every couple weeks for work and park in a tiny parking garage.
    That's what it looked like to me. I only had time to check it out if it was simple to get to I.e. Nothing needed removed. I'll try and dig into it this weekend.
  11. Feb 11, 2017 at 7:21 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I've got the exact same issue with mine. I'm taking mine to the dealer on the 21st of this month to see what's up. The thing is I could turn it off and leave it off but I didn't pay extra for the sensors to turn them off. I want them working!
  12. Jul 10, 2021 at 3:16 PM
    SAGE63
    San Diego County
    Did you get this resolved
  13. Jul 10, 2021 at 4:18 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    If the plastic is cracked where the sensors mount and they aren't pointing quite straight, that will cause the system to constantly think you're about to hit something.
  14. Jul 10, 2021 at 8:35 PM
    SAGE63
    San Diego County
    My issue on my 21 crewmax is All 5 parking sensors are in error. white circle with red line through it. started when replaced stock 275/65r18 tires with 295/70r18. All worked fine with 3" leveling lift with stock rims and tires. All TSS systems working fine. Dealership cannot fix. They did a zero point calibration which has nothing to do with parking sensors. Anyone know how to clear and fix the parking sensor error
  15. Jul 19, 2021 at 12:46 PM
    SAGE63
    San Diego County
    ok so it turned out to be a disconnected sensor. apparently an open in the circuit causes all sensors to report as malfunctioning. vs the offending sensor, or at least that is what the dealership advised me today.
