Parking Brake Question
Discussion in '2.5 Gen Tundras (2014-2021)' started by niru316, May 2, 2017.
Do you use your Parking Brake?
  1. Yes
    65.7%
  2. No
    28.6%
  3. Sometimes
    5.7%
  1. May 2, 2017 at 9:43 AM
    niru316
    niru316 [OP] New Member
    2017 Tundra TRD Pro CrewMax
    Question for everybody! I've always driven a manual vehicle so using the parking brake has always been a given. But it was brought to my attention while talking to my cousin who has more mechanic experience that me (seeing as he is a mechanic) and a few google searches. Saying the following when parking your car (even automatic vehicles):
    1. Pull into parking space
    2. While car is still in drive and foot is on brakes engage Parking Brakes
    3. Put car in Park
    4. Take foot off brakes.
    and reverse for leaving parking spot.
    The claim is its better/easier on your transmission, which i can understand. The example that was brought up was.
    Have you ever put your vehicle in park and when you release the food brake your vehicle still rolls forward a little bit? I have... not necessarily in the Tundra but in other vehicles. The idea is that little roll causes unnecessary tension/friction and in the long run of things is bad. I'm no mechanic by any means so i'm not sure how true or how much damage this does.
    So besides the parking brake question... Has anybody else noticed a Roll in their tundra? with or without the parking brake? Do you do the method above? Do you live somewhere with a lot of hills? Or somewhere flat?
    I personally live in Florida where it is flat... So I never thought about using the parking brake in an automatic. So now i'm trying to instill that into my routine need my tundra to last FOREVER! :benchpress:
    :edit:Grammar
  2. May 2, 2017 at 9:51 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Watching to see what the recommendation is. I've only used once or twice and usually engage parking break once car is in park and off (or just before I turn off). Never really had much of a need to parking break since car is automatic.
    niru316[OP] likes this.
  3. May 2, 2017 at 9:52 AM
    JC303
    JC303 Same same but different
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    I always use my parking brake and follow the above steps, sometimes I put it in neutral before applying the parking brake. Came from a manual trans and had a mechanic tell me the same thing your cousin told you. Not sure if it helps take pressure off of the trans but what can it hurt...
    Les7311 and niru316[OP] like this.
  4. May 2, 2017 at 9:52 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Might make a difference in the long run if you park on a hill every single day... maybe. I rarely do so I'm not even going to stress on it.
  5. May 2, 2017 at 10:01 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Never put on my parking brake unless I'm on a good incline, which is VERY rare
    niru316[OP] and NewImprovedRon like this.
  6. May 2, 2017 at 10:05 AM
    niru316
    The way my cousin said it was VERY LONG TERM like I may never see an issue due to this but if I planned on keeping the truck LONG term it wouldn't hurt do to the steps above.
  7. May 2, 2017 at 10:07 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    And I would think its releasing the foot brake after putting it into Park and then the truck moving and putting pressure on the transmission that is bad. I think it would actually be better to put in Neutral, press parking brake, release foot brake to let it settle, press foot brake again, then put it into Park.
  8. May 2, 2017 at 10:08 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    I use my parking break every time.. just a habit.. but for sure use it before you put it in park.. when you put in park then use break after, you hear a loud CLUNK noise from tranny. Always use break before shifting into park..
  9. May 2, 2017 at 10:08 AM
    Newm
    Newm New Member
    KC
    Use my parking brake unless it's just a super flat parking lot/garage. I try and avoid the extra tension on the parking pin.
    Here's my routine....not sure if it's correct but it seems to avoid the bang/clunk when parked on a hill.
    With my foot still on the brake pedal I put the truck in park
    With my foot still on the brake and truck in park I set the parking brake
    Foot off brake
    Hope out and give a quick look back at that badass Tundra :thumbsup:
    On Edit: I should add that on a bigger hill or incline I will put it in neutral and set the brake just to see if I have the parking brake set firm enough to hold the truck without the help of the trans.
  10. May 2, 2017 at 10:10 AM
    niru316
    Haha ya I do that last part... I always look back and am like DAMN she looks good!!! and im not talking about my wife haha
  11. May 2, 2017 at 10:13 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I just learned a new technique from @boardude. If you want to look back at your truck and don't want to be obvious that you're just turning around to look at your truck, pretend the remote lock isn't working and pretend to try to push the remote button while you're looking back. :D
  12. May 2, 2017 at 10:14 AM
    niru316
    lol I will use this next time haha!
  13. May 2, 2017 at 10:15 AM
    ToyotaTundraMike
    2015 Tundra
    Im in FL as well and the only time I use it is when I launch/load the boat.
  14. May 2, 2017 at 10:16 AM
    niru316
    What part of Florida if you dont mind me asking
  15. May 2, 2017 at 10:20 AM
    ToyotaTundraMike
    2015 Tundra
    Panama City. You?
  16. May 2, 2017 at 10:21 AM
    niru316
    Jacksonville
    NewImprovedRon likes this.
  17. May 2, 2017 at 10:22 AM
    ToyotaTundraMike
    2015 Tundra
    Nice, my cousin is there, and I'll be visiting the port in less than 2 months to take my gf on a cruise.
    NewImprovedRon and niru316[OP] like this.
  18. May 2, 2017 at 10:23 AM
    TXMiamiFan
    Jose
    I have no issues being obvious :)
  19. May 2, 2017 at 10:23 AM
    niru316
    Nice! that ought to be fun! taking the tundra for the long drive?
  20. May 2, 2017 at 10:28 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Eso! Exactly. Our trucks are bad a$$!! No issues here of being obvious. :thumbsup:
  21. May 2, 2017 at 10:30 AM
    DVYota
    DVYota Super stock street truck
    South Carolina
    2014 Sequoia 2021 Tacoma
    Basically stock
    My parking brake is out of adjustment and I don't have time to pull the rear wheels off and tighten it... so I just don't use it
  22. May 2, 2017 at 10:32 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Can't tell you how many times my wife has told me that I should really get the remote fixed haha
  23. May 2, 2017 at 10:40 AM
    niru316
    Bwa ha ha ha that's funny
  24. May 2, 2017 at 10:41 AM
    ToyotaTundraMike
    2015 Tundra
    Oh yeah. Its either that or a GMC Terrain lol
    niru316[QUOTED][OP] likes this.
  25. May 2, 2017 at 12:09 PM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    I'm like you, I learned to drive in a manual and my first two vehicles were manual so it's second nature for me to use the parking break. I use the method you stated above. Someone also told me this when I was learning to drive and it stuck. My driveway has a slight slope so I always use the brake. My truck still rolls a little bit after setting the ebrake and releasing the brake pedal. This is in park.
  26. May 2, 2017 at 12:39 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Wow. such a simple thing. so many words.
    use it.
  27. May 2, 2017 at 12:56 PM
    niru316
    I like to tell the full story and ive been told i like to hear myself talk =P
    bobeast[QUOTED], joonbug and Newm like this.
  28. May 2, 2017 at 1:03 PM
    shockinyall
    shockinyall Hillbilly
    West Virginia
    2017 TRDOR CM
    In Queue...
  29. May 2, 2017 at 1:11 PM
    niru316
  30. May 2, 2017 at 6:07 PM
    niru316
    Has anybody else done this and get a small bump when letting go of the foot brake?
