Parking brake failed inspection
Discussion in '1st Gen Tundras (2000-2006)' started by bmf4069, Sep 15, 2018.
  1. Sep 15, 2018 at 3:12 PM
    bmf4069
    bmf4069 [OP] WHO KEEPS CHANGING THIS!
    Beau
    TX
    02 AC sr5 4wd v8
    Went and tried to get an inspection. Only thing that failed is the parking brake. Does this have anything to do with it?
  2. Sep 15, 2018 at 3:17 PM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    Looks like you got a seal leak that’s seeped so badly it got outside. Probably coated the brakes shoes, which is effectively your parking brake. I’d pull that drum off and start investigating where the oil is coming from.
  3. Sep 15, 2018 at 5:08 PM
    Professional Hand Model
    Hand Protectors
    Yeah bud. Seals blown. Mine went at 153k miles.
    BTW my parking brake has never really operated properly since new. Its a design flaw. You can adjust the brake, but its temporary and sucky at best.
    OBXTundra likes this.
  4. Sep 15, 2018 at 6:16 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    So since I'm gonna do the rear brakes anyways, I guess I'll hit the seals too. I'm just guessing that means I'm doing the rear diff juice too. And since I'm doing the rear may as well hit the front and transfer case. It never ends! :(
  5. Sep 15, 2018 at 6:20 PM
    Hand Protectors
    Yours is coming up on that turning point of reinvestment. You get through this work and that front suspension stuff in your other thread and you’ll be good to go for another 17 years.
  6. Sep 15, 2018 at 6:24 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I'm gonna get all this done and the trans is gonna shit itself a week later! :rofl:
  7. Sep 15, 2018 at 6:28 PM
    Hand Protectors
    Noooo! I hear ya. Its a low risk gamble. I’m keeping my eye open on a donor truck just in case. May even get a 1st Gen Sequoia as a back up driver.
  8. Sep 15, 2018 at 6:38 PM
    Bones2012
    Bones2012 2012 CM
    Windy City
    2012 Black Crewmax
    Step Tubes BakFlip VP Dee Zee Bed and Tail gate mats Pop A Lock tailgate lock Smitty Built M1 Rear Bumper Weather Tech mats Interior LEDS Remote control Bed Lights Cabelas seat covers
    I had a seal leak on my 06 and it cost $1000 to repair. not a simple process. Good luck
  9. Sep 22, 2018 at 7:53 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    So I'm about to order parts. Wheel bearings, axle seals, and all new rear brakes. Is there anything else I should replace while I'm in there?
  10. Sep 23, 2018 at 7:53 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I'm just gonna buy a whole new kit for the brakes. New drums, shoes, hardware, and cylinders.
    Watt maker likes this.
  11. Sep 27, 2018 at 9:21 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    After looking through all the various brands and parts I have no idea what I need as far as the axle seals go. Any tips on what I need? I'm doing the seals, bearing and brakes.
  12. Sep 27, 2018 at 11:40 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    For one side, you need an inner oil seal, the bearing, and the outer dust seal, and the hub o-ring. The spacer collar that the inner oil seal runs on is also difficult to get off without damage, as is the tone wheel for the ABS sensor.
    When reassembling, the inner collar and tone wheel DO NOT get pressed tight against the snap ring and the outer spacer collar, and if you do the seal will leak right away. Pressing bearings off the axle shaft is a pain in the butt without any special tools. Here’s a picture of a tool I built to remove the tone wheel and inner collar with a press without damage, and shows what you’ll see when you pull the axle assembly.
    I also built a tool that attaches to the four studs on the hub to press the axle shaft out of the bearing / bearing housing.
  13. Sep 28, 2018 at 5:04 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Thank you! I'm gonna pull the axle and take it to a shop to get everything pressed together. Probably rent a deal pulley to if need be. Any special tools to set the inner axle seal or general dis/reassembly?
  14. Sep 28, 2018 at 5:14 AM
    Hand Protectors
    Post ‘how to’ pics! Make it look easy and I’ll DIY. Otherwise, its going to the shop when mine need done. This looks like a pro job.
  15. Sep 28, 2018 at 6:41 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Is this all I need?
  16. Sep 29, 2018 at 7:18 AM
    Hand Protectors
    Call your stealership and tell them you are diy and ask them for the whole list of parts you need. They do this for their service dept. so should be pretty dialed in. You can also price check with that list from above.
    I did this when doing some other work and the parts lady helped me out with some additional parts I overlooked. $Pent $tealership prices but had ALL the right quality parts with no problems or additional running around.
  17. Sep 29, 2018 at 8:06 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Just missing the o-ring between the hub assembly and the axle housing, assuming the shop that does your pressing can get your ABS tone rings and inner collars off without damaging them.
