Park Assist Malfuntion
Discussion in '3rd Gen Tundras (2022+)' started by nobaddays, Aug 30, 2023.
  1. Aug 30, 2023 at 6:01 AM
    nobaddays
    nobaddays [OP] New Member
    Tyler
    2023 Black Tundra TRD Pro
    Full front PPF, Tint, Go Rhino boards, Retrax, 35's, Rekgen Flaps
    Curious if anyone has run into this or not. Truck was in an accident, but all sensors were intact. After everything was removed and reinstalled I am getting a Park Assist Malfunction warning message.
    The dealer ran the codes and it is showing all 4 front sensors are "missing". They are blaming the accident (rightfully so) and want a lot to diagnose further.
    The button on the bottom left side of the steering wheel doesn't change anything when pressed or held, and the "P" icon in the settings on the digital gauges no longer appears. I checked every fuse in the truck & disconnected the battery overnight and still have not had any luck.
    Anybody have suggestions on where to look next?
  2. Sep 5, 2023 at 7:04 AM
    nobaddays
    Tyler
    Anybody have any ideas? I'd rather not spend thousands having the dealer diagnose, not to mention its my only vehicle.
  3. Sep 5, 2023 at 7:31 AM
    Tom
    Tom New Member
    Who fix your truck? Take it back to them.
  4. Sep 5, 2023 at 8:20 AM
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    I would do this.
    I would also call the insurance adjuster who did the post-accident inspection for the insurance claim and let them know that you've found additional, hidden damage. They should be able to update the claim to cover the additional damage. It shouldn't be too hard for them to do, especially if your dealership can provide documentation that the additional damage (in this case...the sensors) are a direct result of the accident.
    vtown76 likes this.
  5. Sep 5, 2023 at 10:01 AM
    Tom
    Tom New Member
    Gonna be about $800.00 to fix probably.
  6. Sep 5, 2023 at 12:09 PM
    nobaddays
    Tyler
    Thanks guys. Shop is booked out 3+ months. Already had to wait 2.5 months to get it in the first time. Was hoping there may be something simple I could look into instead of looking at the error message for another 3 months.
  7. Sep 5, 2023 at 7:04 PM
    Adventurer
    Adventurer New Member
    2023 1794 TRD 6.5 Celestial Siver
    Follow along the wire harness by hand, look for a connector unplugged/not fully seated or external damage to wiring. There's probably a connector that goes to all of them, near core support area.
  8. Oct 3, 2023 at 11:08 AM
    nobaddays
    Tyler
    It was just a calibration issue apparently. Picking it up from the dealer this afternoon.
    pwpblue, ryanwgregg and Kap1 like this.
  9. Nov 26, 2023 at 9:04 AM
    forrestkrhoads
    forrestkrhoads New Member
    Forrest
    2020 Cement Tundra Limited 4X4
    3" Westcott designs TRD OFF-ROAD PRELOAD COLLAR LIFT KIT, 35" BFG K02 All-Terrains
    Do you know what it cost to calibrate?
  10. Nov 27, 2023 at 7:23 AM
    nobaddays
    Tyler
    It was around $300 to have it done.
    pwpblue and ryanwgregg like this.
  11. Nov 27, 2023 at 8:59 AM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    Making the insurance co pay for it right?
  12. Nov 27, 2023 at 9:01 AM
    nobaddays
    Tyler
    Correct, they paid for it. It was 2 months ago so I forgot the exact amount, but it was covered.
  13. Nov 27, 2023 at 9:09 AM
    pwpblue
    Greensburg,PA
    That's great! Thanks
  14. Nov 27, 2023 at 12:40 PM
    nobaddays
    Tyler
    It was a huge PITA though... I had to go through my insurance first, then my insurance went after his insurance since he was 100% at fault. Made the supplemental claims very tedious, but in the end its fixed and I am not out of pocket!
    pwpblue[QUOTED] likes this.
  15. May 21, 2024 at 9:32 AM
    Vista-Tundra
    Vista-Tundra New Member
    Mario
    Cool Tundra. 1st Truck
    none
    Hello everyone, Thank you for this Tundra forum. I have experience a similar problem. Being a newbie I jack knife while trying to back in my trailer at the campsite. The Insurance paid to repair the damage, however no sensors were damaged. The dealer can not fix PKSB Unavailable and the bottom left Park Assist button is unresponsive. They have me already waste $1000 replacing a sensor and bracket and not fix the problem with the tow hitch on. After the 3rd time at the dealer they assigned the Truck to a Master Tech with no fix result. I'm going to go back to the Insurance based on what I learned here. Can anyone help is this a calibration Issue alone? Thank you
  16. May 21, 2024 at 10:15 AM
    nobaddays
    Tyler
    Depending on your damage, mine ended up having a broken wire in the sensor harness that I could barely see until I took it apart and went over it with a fine tooth comb. Then they had to calibrate it from there.
