Park Assist Function?
Discussion in '2.5 Gen Tundras (2014-2021)' started by 1949RC, Feb 19, 2020.
  1. Feb 19, 2020 at 11:52 AM
    1949RC
    1949RC [OP] New Member
    2016 Tundra Platinum
    Bought used 2016 Tundra Platinum. It has the Park Assist Function. I have tried several times, and even though the light on the switch is on, it doesn’t seem to do anything in reverse or forward gears. No warnings of any kind. Book has several pages, but this just doesn’t seem to function. Help.
  2. Feb 19, 2020 at 12:01 PM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    Not sure about 2016 but I assume it’s similar to my 2018. Go through the settings in the heads up display to see if anything has been turned off. Do you have aftermarket bumpers? Are the sensors still there, intact, and/ or plugged in?
  3. Feb 19, 2020 at 4:59 PM
    1949RC
    Stock bumpers. Sensors appear to be there and intact. Can you tell me what the warnings sound like?
  4. Feb 19, 2020 at 6:02 PM
    KnuckleHD
    You should hear beeping and see something appear on your screen. Are you getting close enough to set them off? Different vehicles have different sensitivities. I have to be pretty close in the tundra for them to go off. My Camry on the other hand will go off when I’m in bumper to bumper traffic. Put the truck in drive with your foot on the brake and have a friend stand next to or wave their arm in front of the sensor. If they still don’t go off then I’d say something is wrong with the sensors or they aren’t connected.
  5. Feb 19, 2020 at 8:36 PM
    1949RC
    I’ll try that. Thank you.
  6. Feb 19, 2020 at 8:52 PM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    Try a drive through ... mine seems to only go off in the drive through when i'm paying or grabbing my bag of food. Thing beeps like crazy and then I still have to reach to get my food. :)
    You could also have someone walk in front of the car while you are in there with your foot on the brake in drive and see if they go off ... which they should.
  7. Feb 19, 2020 at 10:06 PM
    1949RC
    It did go off once at a coffee stand drive-thru, but I don’t believe Park Assist was on at that time. However, your suggestions a very good and I will try them.
  8. Feb 20, 2020 at 12:10 PM
    TTund16
    TTund16 New Member
    The front sensors need a little bit of angle to them before beeping or flashing LED like you need to be turning a little as oppose to going straight.
    check your fuses!
  9. Feb 20, 2020 at 7:32 PM
    1949RC
    I finally was able to confirm the sensors are all operational. I was mistaken in believing that they were there so when pulling into parking you didn’t pull to far forward and hit the car in front of you. At least on the front, they appear to be more side warning system. The back sensors probably warn of rear objects, but you have the backup camera for that.
    Thanks to all who replied, your suggestions really helped me learn how and where they work. It really did help.
    KnuckleHD likes this.
  10. Feb 20, 2020 at 7:39 PM
    KnuckleHD
    Glad you got it figured out. That’s what we are all here for.
  11. Feb 20, 2020 at 7:40 PM
    KnuckleHD
    Well that and sarcasm, giving people a hard time (in good faith), and helping others spend a ton of money!
  12. Feb 20, 2020 at 7:41 PM
    WNY PAT
    WNY PAT New Member
    Western New York
    2017 Crewmax Limited (Mines) 2019 Crewmax SR5 (Work)
    They ought to beep when you’re getting too close to the vehicle in front of you when you’re moving slowly. Also, if you sit in a parking spot with the back end out a bit while in reverse with your foot on the brake, you should get a cross traffic warning alert as well as other cars move past you. As you know, the BSM and P lights must be on for all the passive BSM, cross traffic alert and parking proximity functions to work.
