Pardon my dumb question..Asking for my dog
Discussion in '1st Gen Tundras (2000-2006)' started by MN_Byrdie, Nov 3, 2024.
  1. Nov 3, 2024 at 7:13 PM
    MN_Byrdie
    MN_Byrdie [OP] New Member
    2006 Toyota Tundra SR5
    This is probably a ridiculously dumb question...but my rear window opens all the way and my xxlarge(160lbs) loves her car rides and likes to stick her head out and rest it on the center headrest. Whether it's raining or snowing she doesn't care but then everything in the back seat gets wet. Do they make some kind of rain guard I can place on the sliding rear window or any ideas?
  2. Nov 3, 2024 at 7:15 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L “Best Cab”/AC Limited 50k mi
    You have the Double Cab with the back window that rolls down all the way?
  3. Nov 3, 2024 at 7:17 PM
    MN_Byrdie
  4. Nov 3, 2024 at 7:19 PM
    Foster1
    Foster1 New Member
    2023 TRD Off Road
    I don't have a solution but just wanted to say cute dog
  5. Nov 3, 2024 at 7:29 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Weathertech makes a good seat cover for the rear seat if you're just trying to protect the seat. If you're trying to protect the interior bulkhead, behind the seat, you may be able to use 2 or 3 of their rear door interior protectors (which are about 26" wide/ea and secure by sliding down the window channel and the 'protector would just sit on the bulkhead between the panel and rear of the rear seat.
    If you're wanting an exterior mounted sunshade rain deflector, you could try something like this...
    https://gtsstyling.com/product/toyo...BHVdaqAXwPlADA2Ht48--angkFT_d3qcaAkw8EALw_wcB
    bulldog93, Tlar25 and Weagle like this.
  6. Nov 4, 2024 at 4:30 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I'm not sure you can do anything other than cover the parts of the back seat getting wet. If the back window is the only open window, there will be rain or snow sucked into the cab. Not a ton, but enough to get stuff wet.
  7. Nov 4, 2024 at 4:46 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    I'd just get a bike mat for the tail gate and throw it back there.
    KNABORES and FrenchToasty like this.
  8. Nov 4, 2024 at 6:32 AM
    shifty` I'm having daydreams about night things
    Awesome pup. I saw this online recently. Would something like this work for you? Install this and only roll window down 2/3 so pup can still shove that snout out.
    Weagle, bulldog93 and OldGuy03 like this.
  9. Nov 4, 2024 at 6:51 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    2003 V8 SR5, Access Cab, 4x4, White
    Probably an unpopular opinion, but why would you roll the window down if it's raining or snowing? I get that people adore their animals and would do almost anything for them, but would you allow a child to roll the window down in a rain or snow storm? Would you admonish that child and tell them to roll the window back up? It's raining/snowing for godssake! You can't blame anyone but yourself for wet, stinky, and moldy upholstery. Sometimes you just have to put your foot down and let the dog know who's boss. The dog will certainly appreciate the reward of the window down on sunny days.
    The only other solution would be building some sort of awning if you just can't bring yourself to tell your dog no.:notsure:
  10. Nov 5, 2024 at 4:09 AM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    I wouldn't mind one of these. Just hard to tell which ones are truly made for a double cab with the window that rolls down. Many attach directly to the window
