Parasitic Draw on Battery
Discussion in '2.5 Gen Tundras (2014-2021)' started by mattyA, Sep 12, 2020.
  1. Sep 12, 2020 at 7:30 PM
    mattyA
    mattyA [OP] New Member
    2018 CM 1794
    Level Kit front/rear TRD Pro exhaust
    I have a 2018 CM 1794 and had a couple of rough starts followed by a dead battery needing a jump. I had the dealer check it out and they said the battery was fine. I'm going to be towing a trailer in a few days so I wanted to get to the bottom of it. Have about a 0.5 amp draw and found the circuit. Anyone know what ECU-DCC is? See pics below. Thanks!
  2. Sep 12, 2020 at 7:37 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    ECU should be your computer. Curious has you isolated it to that.
    Are you getting you meter in the loop for current measurements?
  3. Sep 12, 2020 at 7:41 PM
    mattyA
    2018 CM 1794
    Pretty sure. I pulled a bunch of other fuses and the amp meter didn't budge. Pull that one and it goes down every time. The only thing I could think with the ECU is that I have a pedal commander but I didn't think that would affect the ECU.
  4. Sep 12, 2020 at 7:47 PM
    Trooper2
    JR
    The PC shouldn't be the issue but you should eliminate it as a possibility. I would remove it for a quick check anyway, you never know.
    2018 still under warranty? If so maybe dealership time.
  5. Sep 12, 2020 at 8:09 PM
    mattyA
    2018 CM 1794
    I was afraid of that. I did find that it’s hard to get an accurate reading because the truck knows when the hood is open and will display it on the center screen. Kept the multimeter hooked up and closed the hood. Still a draw, but only 300 mA.
  6. Sep 12, 2020 at 8:12 PM
    Hartsy8
    Hartsy8 Resident Hockey Guy
    Max
    2020 MGM 1794
    I’ll be interested to hear what this ends up being
  7. Sep 12, 2020 at 8:29 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
  8. Sep 12, 2020 at 8:35 PM
    mattyA
    2018 CM 1794
    I saw those posts, but the DCC in those cases is in reference to a short, not an actual fuse. I have a short as well (you can see its location in my first picture, above the 20 amp fuse that is the problem circuit). Maybe it is just a pull for long term storage, but I thought that was what the short was for.
  9. Sep 12, 2020 at 8:48 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    So you have a fuse in Short and in ECU-DCC?
  10. Sep 12, 2020 at 8:53 PM
    mattyA
    2018 CM 1794
    Correct
    but the fuse in short doesn’t have an amp listed on it. I’ll try and snap a picture of it tomorrow
  11. Sep 12, 2020 at 8:57 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    All that comes to mind for me with DCC is DC cut, I cant think of anything else at the moment.
    Electrical gremlins man, take it to the dealer if your under warranty. I know it may not be ideal though.
    Even 69mA I think is above Toyota allowable spec.
  12. Sep 13, 2020 at 1:32 PM
    mattyA
    2018 CM 1794
    Ok, so new twist. I jammed a screwdriver into the hood latch to make the truck think the hood was closed. If I wait a few minutes without touching anything, the amp draw drops to 50mA. So no parasitic draw. BUT, as soon as a turn my engine over, it dies. Try it again and it turns on fine. Happens if I don’t drive my truck for more than an hour or so.
  13. Sep 14, 2020 at 6:45 PM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    The Tundra's ECU draws a ton of power. My battery typically drains significantly in a week if the truck just sits.
    hightechcoonass likes this.
