Panther wheels
Discussion in 'Wheels & Tires' started by Lighterknot1974, May 4, 2019.
  1. May 4, 2019 at 11:55 PM
    Lighterknot1974
    Lighterknot1974 [OP] New Member
    Jake
    2019 crew max SR5 4x4
    Black out badges, 4/2 lift level, led lights inside and out
    I am looking at a set of Panther off-road 580 20x9 wheels. They have a 0 offset with 5” back spacing. The hub bore says it is 110.2 but from what I have seen so far I need a rim with 110.5 to fit on my 19’ crew max. I have seen a few posts of guys running 110.1. Will these work or do I need to see if they can make the bigger bore?
  2. May 5, 2019 at 3:47 PM
    Zum
    Zum New Member
    NS Canada
    Don't know for sure but a mm is pretty small and your talking a fraction of it.
    Half a mm would be approx.1/64 "(mm to inches converter)and your talking less than that.
  3. May 5, 2019 at 8:09 PM
    Lighterknot1974
    Jake
    Right, that’s what I was thinking, but I also don’t want to buy a set of rims I can’t use because the center bore is too small
    jewsNbrews likes this.
