Panoramic Sunroof Shade Not Working
Discussion in 'Electrical' started by lyo4669, May 21, 2023.
  1. May 21, 2023 at 6:16 AM
    lyo4669
    lyo4669 [OP] New Member
    Jared
    2022 Tundra -platinum
    Hello,
    I recently purchased a 2022 Tundra Platinum and I’m having an issues with the powered panoramic sunroof shade. I could take it back to the dealer for warranty repair; however I’m hoping to fix it myself. The shade is in the fully open position. When I activate the shade switch nothing happens, no noise. I checked the 30amp ‘shade’ fuse under the hood and it checked good. Is this the correct fuse? Suggestions? Any help is appreciated.
    Jared
  2. May 21, 2023 at 7:01 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I understand wanting to fix something yourself and save the hassle, especially if the dealership is far away. BUT it is under warranty and should be taken care of by the dealer. If you happen to screw something up or find out something you tore apart wasn’t the issue, then it could void future warranty work on that component.
