Panic build....
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jengel451, Nov 18, 2018.
  1. Nov 18, 2018 at 10:44 AM
    Jengel451
    Jengel451 [OP] Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    Well, maybe not so much a "panic" build, but I caught a screw in a back tire yesterday which went into the sidewall. I'm selling the idea if pulling the trigger on things sooner than later based on the fact that the tire is junk and It wouldn't be be fiscally prudent to buy a new tire that i'd just be throwing away in 6 months anyway. And you know, with the Black Friday deals about to pop up, it may make sense to save some money on things I'd be buying anyway.....you know, trying to be fiscally responsible and all.
    Let's just say that I did get the "Dark Look" with some eye rolls, but I did NOT get a "no", not yet anyway, hence my "panic" build.
    So, after burying myself in pages upon pages of information, I think I have a game plan; The idea is to do a small lift, just enough to clear tires, but I also need to be able to load dirtbikes without a ladder etc. I also want to have a little rake as I will be putting about 5-600 lbs of gear in the bed a lot. I don't Off Road a bunch, that's what dirtbikes are for, but I will play around a little if the opportunity presents itself. I admit, I'm going for a "look" more than anything, i'm getting old, my dick is getting smaller ever day and I need to prove something.
    Here is my plan, let me know if this is bunk or not:
    Wheels: Icon Rebound 17" +25 offset
    Tires: 315-70-17 (Still debating brand/model, but an AT)
    Suspension: Bilstein 6112/5160 2.5 ish front, 1-2 rear (I'd like to go one clip from max and use shims to make up the difference so I can keep a good ride)
    I'm prepared to remove mud flap fore/aft as well as heating up some plastics to make things fit. Body Mount Chop is NOT off the table at all. I has tools and a Mig, I can weld like shit but make it look okey dokey with beer.
    jewsNbrews, Ostrich, TheBeast and 7 others like this.
  2. Nov 18, 2018 at 4:32 PM
    Stig
    Stig New Member
    In that case, the only answer is 37s on a 7 inch lift. Don't forget the chrome truck balls hanging from the hitch. You can probably get all that done in panic mode at a shop overnight. Good luck
  3. Nov 18, 2018 at 4:34 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I love this post...lol
    TheBeast and Black Wolf like this.
  4. Nov 18, 2018 at 6:14 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    With that offset, those bilsteins and few coachbuilder shims to 3", 37s will fit
    Rica25 likes this.
  5. Nov 18, 2018 at 6:31 PM
    Jengel451
    The Bitterroot, MT
    Hmmm. With just a mount chop?
  6. Nov 18, 2018 at 6:35 PM
    Berdine
    Binghamton, NY
    Yes, there's a few people running them now. Look up sean hillaker and black pearl build. There's another guy on here Franco matic or whatever his name is on here, running 37s, on 3" +25mm and did body mount, truck looks awesome!
  7. Nov 18, 2018 at 6:40 PM
    Jengel451
    The Bitterroot, MT
    I'll take a look. Just wonder how much of a hit on acceleration and braking over a 35.
    Berdine likes this.
  8. Nov 18, 2018 at 7:06 PM
    Jengel451
    The Bitterroot, MT
    Found a couple 37 pics. I'm gonna stick to 315 / 35's.
    Berdine likes this.
  9. Nov 18, 2018 at 8:56 PM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    Hey man, I am planning the same exact setup for my 18. 2.5" in front, 1" in rear. Same rims, same tire size. What have you seen as far as how much cutting we'll have to do?
  10. Nov 19, 2018 at 5:28 AM
    Jengel451
    The Bitterroot, MT
    From what I'm reading and hearing, minimal if any at all on the body mount. will need to cut/mold/remove plastics though. Maybe trim the skid plate. Depends on tire.
  11. Nov 19, 2018 at 6:37 AM
    Jengel451
    The Bitterroot, MT
    Update: going with Cooper ST Maxx 315/70/17's. I've used the ATP's in the past and have zero issues with them, should last a while and be good in rain.
    So far, the Minister of Finance hasn't shut me down yet.
  12. Nov 28, 2018 at 6:29 AM
    Jengel451
    The Bitterroot, MT
    Parts be arriving. Some changes: Adding SPC UCA's and only doing a 2" in the front with a 1.5 rear so I'm not ass low when hauling. On paper with the adjustable UCA's I should be able to make the 35's fit without doing a chop....on paper. I've seen others doing it.
    Rica25, jewsNbrews, Ostrich and 2 others like this.
  13. Nov 29, 2018 at 12:24 AM
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    This reminded me of a guy on tacomaworld that had a flat tire and then went full boar with long travel. Not that extreme but..you know.
  14. Nov 29, 2018 at 5:48 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Lol! Badass. He should’ve put trax on
  15. Nov 30, 2018 at 9:57 AM
    Jengel451
    The Bitterroot, MT
    awwe hell. UPS just dropped off the rest of the suspension parts I was waiting on. My wife was/is home......... I'll be working through that today.
    ANYWHO, I think i'm going to tear into it this weekend and get an alignment done on Monday. I've been looking for some alignment specs I can give the shop, but all i've seen is screenshots of "bad" ones. Anyone have good numbers I can give the shop?
    2" front, adjustable UCA's (Just in case I need to move them forward for clearance)
    1.5" rear
  16. Nov 30, 2018 at 10:05 AM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    I run a bit more lift in the front than you, 3.25"/1". But here are the numbers that I have for my latest go round:
    Camber: 0.0 degrees
    Caster: Get as much as you can. I have 4.5 degrees left/4.8 degrees right.
    Toe: +0.12 degrees per side.
    I actually wanted to go slightly negative on camber, but this is all I could get. My last go round was +0.2 degrees and that gave me some significant outside tire wear. If the tire wear continues, I will lower the front some and see if I can get some negative camber. I also run no front track bar and drive fairly aggressively, which might also contribute to the outside edge tire wear.
    Talk with @jberry813 . He is good with alignment numbers.
    Jengel451[OP] likes this.
  17. Nov 30, 2018 at 11:45 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Well I don’t have your lift specs but here’s mine done from my local stealership
    I’m on a 6” Readylift w/2 more from Foxes.
  18. Nov 30, 2018 at 12:20 PM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    I'm on 3/1 via 6112+shim and 5160 with Toytec shackles. I stuffed 37x12.5 with no rubbing at full articulation and at full steering lock after minor trimming, lol.
    Nickj619, monaco730, aperezsh and 6 others like this.
  19. Nov 30, 2018 at 1:50 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Sure helps if you don’t have negative offsets and the right backspacing on your wheels.
  20. Nov 30, 2018 at 1:54 PM
    Jengel451
    The Bitterroot, MT
    No UCA's? and define "Minor"
    TheBeast likes this.
  21. Nov 30, 2018 at 2:00 PM
    TheBeast The Beach
    37's..minor trimming...:D:spy:
  22. Nov 30, 2018 at 2:02 PM
    Jengel451
    The Bitterroot, MT
    Exactly, could mean "Small Plasma Cutter"
    Atomic City Tundra likes this.
  23. Nov 30, 2018 at 2:02 PM
    Guhner123
    Guhner123 New Member
    Gunner
    2017 Tundra SR5 MGM
    Toytec/Eibach 3/1 lift kit 295/70/18 TOYO AT 18 Inch Method NVs
    I rubbed with 295/70/18 on methods +25 offset with a 3/1 with SPC UCAs :eek:
  24. Nov 30, 2018 at 2:05 PM
    Jengel451
    The Bitterroot, MT
    Which is interesting as folks have done that exact setup with no rubbing, remove flaps, mold plastic and push UCA's forward as much as possible.
  25. Nov 30, 2018 at 2:06 PM
    Guhner123
    Gunner
    2017 Tundra SR5 MGM
    It’s all very Intresting I didn’t need a BMC but I needed to cut into the front fender liner. Not a big deal at all though!
    Jengel451[QUOTED][OP] likes this.
  26. Nov 30, 2018 at 2:12 PM
    matictundra
    Franco
    AZ
    Minor cutting using angle grinder circled in green. This is my 1st time cutting metal.
  27. Nov 30, 2018 at 2:21 PM
    Midnite72
    Midnite72 Anything DIRT !!
    Bill
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
  28. Nov 30, 2018 at 2:30 PM
    Bates5450
    Bates5450 Elephantitus
    Jacob Bates
    Dickinson, ND
    2018 SR5 CM Cement 4x4
    Good looking truck! Are those 37/12.50R20’s?
  29. Nov 30, 2018 at 2:43 PM
    matictundra
    Franco
    AZ
    Yes with +20mm offset.
  30. Nov 30, 2018 at 2:45 PM
    matictundra
    Franco
    AZ
    I do have optional JBA UCA but not really required.
