Pan American Highway Tundra thread
Discussion in '2.5 Gen Builds (2014-2021)' started by coexplorer, Dec 22, 2020.
  1. Dec 22, 2020 at 4:35 PM
    coexplorer
    coexplorer [OP] New Member
    Graham
    I am starting this thread to both document, and ask questions, for my Tundra build.
    I bought my 2016 Limited about a year ago. It has roughly 30K, and I am slowly building it to take my wife and I to Ushuaia. Shooting for 2023 or 2024. It will be a slow build, but that will give us plenty of time to save and get the truck like we need.
    Here are the plans
    OVRLND Camper (July-ish 2021)
    Heater
    Pressurized water system
    Solar with battery system
    Inverter
    Lift with additional payload capacity (thinking Ironman)
    Tires (thinking 285/75r18 cooper ST Maxx)
    Half Assed, TheBeast, rockmup and 2 others like this.
  2. Dec 22, 2020 at 4:35 PM
    coexplorer
    Graham
    Question for you guys, anyone ever tapped into the fuel line/tank for a gasoline heater?
  3. Dec 22, 2020 at 5:01 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Wow! Had to google Ushuaia - that is one hell of a road trip. You should start a build page and then a travel page once you hit the road.
  4. Dec 22, 2020 at 5:08 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    I haven't but I would think gasoline would be an inefficient use of fuel for heating - gas vs liquid fuel. Is refilling propane tanks south of the border an issue? Can use propane for heating (Heater Buddy), cooking, and lighting as well.
  5. Dec 22, 2020 at 5:10 PM
    coexplorer
    Graham
    Ha, yes, I have been planning this trip for quite some time. I have bene through a lot of vehicles to get to the one I actually plan to build as well (2016 Taco DCSB, 2017 4runner TRDOR, 2017, Taco DCLB, now the Tundra). I am very please with the Tundra, so am moving forward on the full build.
    Your right, I should do a separate build page and trip report. One problem is that we plan to take 6+ months for the trip, and I do not plan on updating a trip report frequently during that time.
  6. Dec 22, 2020 at 5:15 PM
    coexplorer
    Graham
    Yes, it seems that every country has their own standard for propane fittings and filling. Very common here and in MX, but gets much more challenging one you get into Central and South America. To reduce stops and hassle, I think it is best to go with a gasoline stove and heater. I obviously cannot go anywhere without gasoline, so stopping to fuel up is not an options, and it is WAY more energy dense that propane.
    Black Wolf likes this.
  7. Dec 23, 2020 at 8:22 AM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    I'd add a compressor to your list so that you can carry a full size, deflated, spare underneath. I think that 33.5" or 34" is the max that will fit and the 285/75-18 is almost 35" in diameter.
    mtndds98 and coexplorer[OP] like this.
  8. Jan 11, 2021 at 1:44 PM
    Pangaea
    Pangaea New Member
    BC
    2021 Cement Tundra CM TRD Off Road Premium
    So, I'm trying to see if a 275/75 R18 Duratrac spare will fit underneath, without actually buying and mounting a spare or removing one of my wheels (I'm lazy...) and was measuring the tires this weekend and they are only 33.5". They'd probably come up to 34" without weight on them. I was always told they were 35". Maybe the 9" wheel makes a difference? Maybe I'll be less lazy next weekend. I DO know there is some cutting and bending of brackets to be done.
    coexplorer[OP] likes this.
  9. Jan 12, 2021 at 6:51 AM
    coexplorer
    Graham
    Good to know. From reading some of the other threads I figured I would have to cut and bend a bit. It also seems that the leaf spring shackles can be an issue, but if you remove the guide brackets you can push the tire forward as you are raising it. I'll be curious to see if you successfully get it positioned up there.
  10. Jan 12, 2021 at 9:05 AM
    Trogdog
    Trogdog New Member
    Trog
    North West GA
    2020 Crewmax SR5
    Gasoline makes sense from a logistical standpoint but taping into a modern gas tank with that's sealed for emissions compliance may be more trouble than it's worth. Are you opposed to just carrying a siphon and refilling the heater as needed?
    NewImprovedRon likes this.
  11. Jan 12, 2021 at 1:08 PM
    Pangaea
    Pangaea New Member
    BC
    Yeah... Me too! I was really quite surprised how much smaller than 35" these tire actually measured out at...
  12. Jan 12, 2021 at 2:25 PM
    coexplorer
    Graham
    It does seem like it could complicate a system that you really don’t want to mess with. After doing more research I am leaning towards a diesel heater with a small self contained tank. Adds a bit of a hassle when trying to fuel up with two different fuels, but should not be hard to find. Plus it presents much less of a safety hazard then gasoline if there is a leak or spill.
  13. Jan 12, 2021 at 2:48 PM
    Baja Fundra
    Baja Fundra New Member
    2020 Quicksand Tundra TRD Offroad
    Cant wait to see the OVRLND camper on a Tundra, what options are you going to go with?
  14. Jan 12, 2021 at 3:12 PM
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    Keep everything bulletproof Toyota. I call it stock +. I love my Dobinsons suspension.
  15. Jan 12, 2021 at 5:27 PM
    coexplorer
    Graham
    Think I am doing the barn doors, window on one side. Couple addition inches of height for extra bedding as well. I am going to do a full buildout with heat, pressurized water, electrical etc. but that will take me some time to figure out exactly how I want to set it up for the trip.
  16. Jan 12, 2021 at 5:29 PM
    coexplorer
    Graham
    That’s the idea. Minor upgrades to suspension, and a bit of minor electrical, but I will try to keep it as stock as possible. Toyota engineers are way smarter than me.
    Skey44[QUOTED] likes this.
  17. Jan 12, 2021 at 6:02 PM
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    50720212-AC72-4CA9-B09C-1314F85EA8FE.jpg My x2 power battery is a nice luxury too.
  18. Jan 12, 2021 at 6:05 PM
    Heads up. Hopefully you didn't get it from Batteries Plus. We have at least two premature X2 fails reported here and B Plus wouldn't honor the warranty.
  19. Jan 12, 2021 at 6:07 PM
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    Yup... hopefully it’s a good one. So far it’ll run my fridge and camper “forever” they’re only sold at batteries plus as far as I know a rebranded northstar.
  20. Jan 13, 2021 at 6:07 AM
    coexplorer
    Graham
    The stock battery in my truck is starting to die now. Good to have a recommendation for a quality replacement.
    Jerry311SD likes this.
  21. Jan 13, 2021 at 6:14 AM
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    Northstars are going to be my next choice
    TheBeast likes this.
  22. Jan 13, 2021 at 8:34 AM
    Baja Fundra
    Once my OEM battery kicks the bucket I will be going with Northstars as well, I hear nothing but great things about them
    Jerry311SD[QUOTED] likes this.
  23. Jan 13, 2021 at 9:09 AM
    TheBeast The Beach
    when I was backpacking in some remote countries a long time ago (lol), I had a fuel stove because you couldn't find propane tanks in those countries.
    It was smelling gas each time I would primer/fire the cooking stove and cook my breakfast...lol...but it did work.
  24. Jan 18, 2021 at 2:49 PM
    coexplorer
    Graham
    Had my battery tested over the weekend and it failed, so went ahead and pulled the trigger on this same X2. From what I could find, it seems they are just Northstar's that are rebranded by Batteries plus. 60 month warranty is hard to argue with.
    Strange thing, after I connected the new battery, the truck started great, then immediately shut off after about two seconds. Started it again, and it was fine. I decided to disconnect the terminals and clean them. Once I did that, I started it again, 2 seconds, shutdown. Second time, it started and ran just fine. It has not happened again since then, but I thought that was strange.
    Skey44[QUOTED] and Jerry311SD like this.
  25. Jan 18, 2021 at 6:46 PM
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    That is strange. I’m no expert there for sure but sounds weird.
    I noticed that it turned over slightly differently when I first got it. Don’t notice anything anymore. Probably used to it?
  26. Jan 18, 2021 at 6:51 PM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    I've got a 35x12.5x20 , under my bed , about 1/2 inch on each side of leaf and shackle. No problem.
  27. Jan 18, 2021 at 6:57 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    My truck does that every time I disconnect the battery. Dies immediately on the first start.
  28. Jan 18, 2021 at 7:15 PM
    Dylan7194x4
    Dylan7194x4 New Member
    Dylan
    2013 red cm rw
    If you're going to Ushuaia pack a fly rod. The sea run brown trout it tierra del fuego are legendary. It's a fly fishing bucket list trip for me. Good luck with the build and keep us updated it sounds awesome.
  29. Jan 18, 2021 at 7:23 PM
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    Same
  30. May 6, 2021 at 5:01 AM
    coexplorer
    Graham
    Slowly starting to come together. Next major upgrade was an OVRLND camper. Went down to Flagstaff last week to pick it up, then spent three nights camping in the area.
    rockmup and Cruzer like this.
