Painting chrome trim bezel around shifter
Discussion in '2.5 Gen Tundras (2014-2021)' started by Pudge, Jun 27, 2018.
  1. Jun 27, 2018 at 9:59 AM
    Pudge
    Pudge [OP] Super Secret Elite Member #7
    CT
    2015 Blue Ribbon Platinum
    I posted some pics yesterday of it done and painted and several asked how to get it off to paint it. I just took some pics to show. Mind you all that this isn't step by step cuz its already done and pics taken after the fact.
    First pull off the big trim around shifter, it's just pulls off. No screws.
    You end up looking like this
    Then you need to remove the plastic trim. This is one piece with chrome bezel and shift indicators. There are 2 little tabs on each side. When you get one side unclipped , you can just pull it off with a little wiggle. I pointed to the clips with screwdriver
    Then turn that plastic trim piece upside down. There are some little black plastic welds / epoxy beads that hold the chrome piece on. Cut those with a sharp chisel. The chrome part will slide out through the bottom. You can see where I used hot glue in place of the epoxy in this pic.
    Clean and paint your chrome with whatever you want. I used duplicolor trim paint. Let it dry and stick it back in, use epoxy or hot glue to hold it in place. Then stick it all back in reverse order and you're done.
    The chrome surrounding the cup holder just pops off, very easy. Just clean and paint that too.
    The little chrome trim piece on the bottom of the shifter also comes off with a little pop with a flat screwdriver. That just needs to be cleaned and painted too.
  2. Jun 27, 2018 at 10:39 AM
    Great job! I did same few weeks ago, painted black but might redo paint match
  3. Jun 27, 2018 at 10:40 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Nice write up dude:thumbsup:
    Now we need one for the dash vents!
    Silv333, DecalsByDesign and Pudge[OP] like this.
  4. Jun 27, 2018 at 10:42 AM
    big_jarv
    big_jarv New Member
    2021 TRD Pro
    Thanks for sharing!
    I hope to do this soon.
    Pudge[OP] likes this.
  5. Jun 27, 2018 at 10:42 AM
    I believe @SR5TRDTUNDRA did this, and I saw someone else's post, ther is vinyl decals that can go over chrome bezels maybe @DecalsByDesign can do this for us
  6. Jun 27, 2018 at 10:44 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Thanks
  7. Jun 27, 2018 at 11:17 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Yup sure did. :thumbsup:
    jewsNbrews likes this.
  8. Jun 27, 2018 at 11:39 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Having trouble locating your chrome vent thread/post, little help?
    Y0TA PR0[QUOTED] likes this.
  9. Jun 27, 2018 at 11:48 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Thank you for going through the trouble to go back and taking apart again to show this. Much appreciated.
    Pudge[OP], texasrho83 and jewsNbrews like this.
  10. Jun 27, 2018 at 11:49 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Super easy to do. Loved the results. I just wanted to kill the sun glare so went matte black.
  11. Jun 27, 2018 at 11:55 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Looks good.
  12. Jun 27, 2018 at 12:05 PM
    fullofbs
    fullofbs Project SnowFlake
    Great look
  13. Jun 27, 2018 at 12:22 PM
    Y0TA PR0
    Rafael
    2017 TRD PRO
    It’s on my build thread. I never did a actual thread about how to take them off and paint them. If that’s what your wondering.
  14. Jun 27, 2018 at 12:59 PM
    easleycrawler
    Travis
    Easley, South Carolina
    2020 Limited DC 4X4 CEMENT
    Does this silver piece pop off as well or did you tape it off?
  15. Jun 27, 2018 at 1:02 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    It comes off. I wanted it completely off so I could get every mm painted black
  16. Jun 27, 2018 at 1:03 PM
    easleycrawler
    Travis
    Sweet, I will be doing this this weekend. What paint did you use?
  17. Jun 27, 2018 at 1:32 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Rust inhibitor matte black rattle can lol. All I had. Turned out perfect (to me)
  18. Jun 27, 2018 at 1:34 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    By the way, you don’t have to pry off the piece in the OP’s post. Just remove the trim screws and the whole console piece will pry off.
  19. Jun 27, 2018 at 3:56 PM
    Pudge
    CT
    Huh? I didn't remove any screws you dont need to.
  20. Jun 27, 2018 at 4:05 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    In order to take off the whole piece like I did you do. I didn’t remove the shifter plate like you did.
    Pudge[QUOTED][OP] likes this.
  21. Jun 27, 2018 at 4:07 PM
    Pudge
    CT
    Oh ok I gotcha. You painted more than just the chrome too. That makes sense. I only wanted to paint chrome and didn't wanna deal with taping pieces off.
  22. Jun 27, 2018 at 4:37 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I didn’t wanna tape anything either.
    Silv333 likes this.
  23. Jun 27, 2018 at 4:43 PM
    Pudge
    CT
    So did you paint that whole thing black? And the shifter trim? And no taping means you painted over the gear shift indicator?
    Part of my center console area is padded leather, the part around the shifter that I had to pull off. Maybe thats only a platinum thing?
  24. Jun 27, 2018 at 4:47 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    No, the rest was already black. I have an SR5 so the only “silver” part is the piece around the shifter plate and the chrome bezel around the cupholders. I removed both of those pcs and blacked them out, reinstalled them into the main housing, and reinstalled the whole piece onto the rest of the console.
    icodeintx and Pudge[QUOTED][OP] like this.
  25. Jun 27, 2018 at 4:49 PM
    Pudge
    CT
    It would be really nice of @DecalsByDesign could make up something to stick on the front of the vent bezels without having to remove and wrap or paint them. One company makes stick on pieces but I didn't like the looks of the fit and finish from pics I've seen. Definitely room for improvement as far as I can tell. It's pretty much impossible to have 100% coverage without removing the part and wrapping or painting but a good fitting decal on the face would be a huge improvement
  26. Jun 27, 2018 at 4:52 PM
    Pudge
    CT
    Seems like more work than my method of just removing the parts you want to paint.
    Thanks for the tip on removing that piece cuz I'll have to remove it soon so I can sound deaden under there. Have you ever removed the center console too? Seems like a chore that I'm not looking forward to
  27. Jun 27, 2018 at 4:53 PM
    Someone on here posted pics of decals on ther bezels forgot who looked good
  28. Jun 27, 2018 at 4:54 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Problem is that the temp changes between hot and cold (AC on full blast) would probably make the decals eventually peel imo
  29. Jun 27, 2018 at 4:56 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Took me all of 3-4 minutes to pull the whole piece off. Longest part was the painting and drying.
    No and I don’t want to lol.
    1UPPER and Pudge[QUOTED][OP] like this.
  30. Jun 27, 2018 at 4:59 PM
    @Pudge on pages 613 and 614 on the What have you done to your 3rd Gen Thread
    Pudge[OP] and Y0TA PR0 like this.
