Painted Calipers
Discussion in 'Wheels & Tires' started by boardude, Nov 7, 2015.
  1. Nov 7, 2015 at 3:31 PM
    boardude
    boardude [OP] I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Couldn't find anyone on here who has painted their calipers and shared, so thought I would. I used Rust-oleum high heat paint and clear coat. I went with the orange engine enamel as that was the closest I could find to match the inferno color. It actually came out pretty close too.
    I first took a wire brush to the calipers to get any grease and dirt off. I only have 6k miles on the truck so there wasn't much. I finished it with some rubbing alcohol to make sure it was clean.
    I left the calipers on and just wrapped the discs in a trash bag. I sprayed the paint a little at a time into a cup and then just painted it on. Did two coats on each side with about 10 mins in between each coat.
    Let dry for a couple hours and then took it for a drive to cure the paint. Then slapped some high heat decals on and sprayed some clear coat. Shot it with two coats of clear, let it sit for about 30 and then took it for another spin to let the clear cure.
  2. Nov 7, 2015 at 3:36 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    SWEET! I so want to do this, if for no other reason than to keep the calipers from looking like rubbish.
    AnonVet and boardude[OP] like this.
  3. Nov 8, 2015 at 1:12 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    I am not a fan of painting calipers, but you sir made it look good. Nice work
    NewImprovedRon likes this.
  4. Nov 8, 2015 at 1:45 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Thank you!
    I've never really been a fan either on trucks and I originally wanted to paint them black mostly to protect them from rust. But then took a chance on the orange and super happy I did!
  5. Nov 8, 2015 at 1:53 PM
    flynbyu2
    flynbyu2 I'm your huckleberry...
    NorCal
    2015 SR5 CrewMax 2WD
    Flowmaster Super 50 / Dual In - Dual Out Exhaust BakFlipG2 Tonneau Cover TRD Rear Sway Bar
    I'm definitely doing all four of mine in the near future. I'm going red and probably use Duplicolor or VHT caliper paint.
    Where did you get the TRD decals?
    Looks great.
  6. Nov 8, 2015 at 2:08 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
  7. Nov 8, 2015 at 3:44 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Wow looks really good
    boardude[OP] likes this.
  8. Nov 8, 2015 at 3:59 PM
    flynbyu2
    NorCal
    I've done these before on my Tacoma using the G2 brand brush on paint. It's more expensive than the spray can, but it is SUPER durable.
    The paint is also self-leveling and dries pretty glossy.
    It's also more time intensive but can't think of a better way to spend a day off.
  9. Nov 8, 2015 at 4:26 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Yeah I only spent like 20 bucks including the decals. I heard good stuff about the Rust-Oleum but I'll have to report back to see how its holding up.
  10. Nov 8, 2015 at 4:37 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Looks great.
  11. Nov 8, 2015 at 4:41 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    Ya looks really good! Would like to do it but not sure what color I would do.
  12. Nov 8, 2015 at 5:31 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I may do black with a dark silver TRD decal. I think that or vice versa would go well with your color scheme.
  13. Nov 8, 2015 at 5:47 PM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    i'm kinda in the same boat with the dark color being my preference but those do look sharp. nice work man!
  14. Nov 8, 2015 at 7:09 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    If my truck was inferno I would definitely do orange though!
    Sunnier likes this.
  15. Nov 9, 2015 at 2:22 PM
    Tundra44
    Tundra44 New Member
    2007 SR5 CrewMax
    King shocks front and rear, Spider trax spacers on Rock Warrior rims, Demello Off-road front bumper with Tuff Stuff 12.5 winch.
    Looks great.
  16. Nov 9, 2015 at 4:45 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    My original plan was to do black with white decals. I took a shot with the orange and just figured I would paint over them if they didn't out well. Black with Silver would look sick on yours!
    MotoTundra[QUOTED] likes this.
  17. Nov 9, 2015 at 4:46 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    yeah red would look good on yours, especially with the black wheels. There are a ton of cheap kits in red you can go with
  18. Nov 9, 2015 at 8:32 PM
    csuviper
    Broomfield, CO
    I might do black with red Trd.
    MotoTundra likes this.
  19. Nov 29, 2015 at 12:06 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Finally got around to painting the rears
  20. Dec 10, 2015 at 2:56 PM
    Fitz19d
    Fitz19d New Member
    2015 5.7 SR5 Tundra
    Black wheel dip. Prodigy P2 Brake Controller
    Still a bit early, but also 1.5 months since the first post. How is the paint doing?
    flynbyu2 likes this.
  21. Dec 11, 2015 at 9:32 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    The fronts are holding up great so far. Been through 2 hand car washes and paint and decals are holding strong. I might hit it with more clear coat in a couple months to keep up the protection.
  22. Oct 15, 2016 at 7:59 AM
  23. Oct 15, 2016 at 8:23 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Yes sir. They come in 4 packs, 2 large and 2 small which I put on the rears
  24. Oct 15, 2016 at 9:42 AM
    Same here
  25. Oct 15, 2016 at 9:42 AM
    Thanks
  26. Oct 15, 2016 at 9:53 AM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    Almost a year later how is the paint holding up? Also did you paint on the clear or spray it?
  27. Oct 15, 2016 at 3:44 PM
    vidman
    vidman New Member
    Rick
    Massachusetts
    Painted mine black so the silver would not show
  28. Oct 15, 2016 at 4:32 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I did mine in silver so that they always look factory fresh.
  29. Oct 15, 2016 at 5:12 PM
    TexasMofo
    TexasMofo New Member
    Chad
    Great Country of Texas
    2017 Toyota Tundra TRD Pro
    Illegal Tint 2 Shims/ 3 inch Shacke
    Balrz likes this.
  30. Oct 16, 2016 at 2:46 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Kinda dirty but holding up pretty well. Gonna wash her soon so Ill probably apply another clear coat after. I sprayed on the clear coat after I put on the decals
