Paint steering wheel trim panels on 14-15 tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by 15TRDPro, Jun 8, 2015.
  1. Jun 8, 2015 at 11:49 AM
    15TRDPro
    15TRDPro [OP] New Member
    Jeremy
    NorCal
    2015 Inferno Tundra TRD Pro
    TRD Supercharger
    this is my first DIY so here we go. If you want to paint or wrap, this is how you remove the trim panels on a 14-15 steering wheel. You'll need a T30 torx, pry tool and Philips screw driver.
    First step is to disconnect the negative battery terminal (10 MM socket)
    On bothe sides of the steering wheel there are 2 small access panels that need to be removed to get to the T30 torx.
    Using a pry tool, pry off those two panels. You'll see a single T30 on each side.
    Remove these, they hold the airbag in.
    Pull straight out on the airbag and set it on top of the steering wheel.
    just reverse the steps to put it back together.
  2. Jun 8, 2015 at 11:54 AM
    Well done! Very nifty.
  3. Jun 8, 2015 at 12:10 PM
    Nice. You should enter this in the unique mod contest! Ill add this to the DIY list.
    Edit: added.
    boelt63A likes this.
  4. Jun 8, 2015 at 12:11 PM
    How do you get off the AC rings to paint those? Also, which paint are you using and how many layers?
  5. Jun 8, 2015 at 12:25 PM
    15TRDPro
    Jeremy
    NorCal
    TRD Supercharger
    the long panel above the glove box is clipped in as is the one to the left of the steering wheel. The ones on the left and right of the nav are a bit more challenging. radio has to be removed and most of the dash to remove the surround around the nav, they are screwed in from the back. took me about an hour to pull most of the dash apart. I used dupli color bed armor spray. I like it because it's textured and I know it will last forever. I put 4 light coats on.
    Mountun Goat and 040Tundra like this.
  6. Jun 8, 2015 at 12:26 PM
    15TRDPro
    Jeremy
    NorCal
    TRD Supercharger
    thanks, I had a lot of trial and error when I was modding my 06 Tacoma x-runner.
  7. Jun 8, 2015 at 12:36 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Good work with the description of pulling it apart.
  8. Jun 8, 2015 at 12:37 PM
    csuviper
    Broomfield, CO
    Now the question is, did you pull apart the TRD shift knob or just tape up the leather?
  9. Jun 8, 2015 at 12:56 PM
    15TRDPro
    Jeremy
    NorCal
    TRD Supercharger
    didn't see any reason to pull it apart, I just removed it and taped it off.
  10. Jun 8, 2015 at 1:12 PM
    Too much work. Im out.
  11. Jun 25, 2015 at 10:17 AM
    15max
    15max New Member
    Cole
    15 SR5 TSS 4x
    3/1 lift level, 35" Toyo Trail Grapplers
    Saving this for later.
  12. Jul 13, 2016 at 2:55 PM
    Truckster1031
    Truckster1031 New Member
    2016 Charcoal Grey Tundra Limited Crewmax 4x4
    Jeremy do you know how to remove and replace the actual steering wheel. I am wanting to replace my stock leather wrapped wheel with one that includes wood grain grips. The place I am looking to purchase from uses genuine OEM Toyota wheel and adds the woodgrain or carbon fiber grips to it and you install yourself and send them back your old wheel in exchange. You use your existing airbag and electrical wheel controls and just swap out the actual steering wheel. They indicate its easy to do yourself and say it can be done in about 30 mins. Problem is I can't find anything to show me how to replace the wheel 2014+ Tundra's. Closest thing I have found is your thread so thought you might know since the instructions you provided would at least be the first few steps in actually removing the steering wheel itself. Any help would be appreciated! Thanks!
  13. Jul 28, 2016 at 3:49 PM
    15TRDPro
    Jeremy
    NorCal
    TRD Supercharger
    Sorry, I didn't really pay much attention to removing the whole wheel. You might try a dealership, ask if they will print you out a schematic for removing the wheel.
  14. Jul 28, 2016 at 6:21 PM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    Looks good! I may actually try doing this!
  15. Apr 2, 2017 at 10:05 AM
    Koke
    Koke New Member
    2014 SR5 Tundra TSS
    Good work!!
    Can't tell by the pic but it looks like the badge is shot as well. Did you remove or shoot the whole airbag?
    Thx
  16. Apr 2, 2017 at 10:41 AM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Thanks for the write up. This is in my to do list eventually.
    Voyagermike likes this.
  17. Apr 2, 2017 at 11:10 AM
    az1441
    az1441 6-0 G7s on the road
    Steeler Country
    2017 Toyota Tundra TRD Pro cement
    4" Readylift 35" Toyo M/T 20x9 0 BMF BATL Retrofit w RGB LED Halos and Strips
    I was just talking about this today as well. Great mod.
  18. Apr 4, 2017 at 11:33 AM
    15TRDPro
    Jeremy
    NorCal
    TRD Supercharger
    I removed the Toyota emblem with a trim tool and painted it.
    Voyagermike and 040Tundra like this.
  19. Apr 4, 2017 at 8:46 PM
    showtime240
    showtime240 New Member
    Man gonna try this with Vinyl. Thanks for the great write up!!
  20. Apr 7, 2017 at 6:26 PM
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    http://www.tundratalk.net/forums/tu...ering-wheel-swap-2.html#/topics/120845?page=2
    Follow this staring at post #18. You can rent a steering wheel puller to make it easier. Make sure you dont thread the two holes on the side of the center nut too deep or it will crack the clock spring. (Ask me how i know). I replaced mine with a tacoma one.
  21. Oct 19, 2017 at 7:19 PM
    dkard
    dkard New Member
    Thanks for the info on this mod - I followed it to the letter and easily pull off the panels on my steering wheel for painting. Simple process!
  22. May 30, 2018 at 10:28 AM
    Koke
    Koke New Member
    2014 SR5 Tundra TSS
  23. Dec 5, 2018 at 10:59 AM
    TundraCoast
    TundraCoast Member In Good Standing
    Ian
    California
    1794 4x4
    1794 on the inside - PRO on the outside
    Nice work on the trim pant, I'm in the process of "de-chroming" my interior as well. I am really interested in how you removed the steering wheel emblem on the airbag. Do you have pics of how you did it or any tips?
  24. May 25, 2019 at 9:19 PM
    SethMcK
    SethMcK New Member
    Seth
    2015 White Tundra 5.7L
    JBA long tube headers with BAMufflers' mids & 7" exhaust, 2019 Pro LED headlights, leveling kit, 20" wheels, retractable tonneau, remote start, blacked out emblems, TRD rear sway bar, all lights replaced with LEDs, lots of other little mods, still working on it...
    Redwinger and Toyotoholic like this.
  25. May 26, 2019 at 5:50 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    X2^^^
  26. May 26, 2019 at 5:54 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Outstanding!
  27. Sep 14, 2019 at 12:27 AM
    dak13
    dak13 Butt Stuff
    2015 Tundra SR5
    You forgot the rings inside the cluster gauge :gossip:
    But seriously, awesome job. I will be doing this here real soon and this helps a lot. I am just trying to figure out what color I want the light gray and chrome trim to be.
    I think I want to match the other dark gray trim as close as I can. I already have cans of Duplicolor in Toyota MGM for the hood bulge and surround. I am thinking that with a matte clear might be good. But I also have black trim paint...
    Might do both somehow :notsure:
    Edit: Also, is there a secret to how you did the volume button? Does it come off with the whole steering wheel trim?
  28. Sep 25, 2020 at 2:07 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    How is this holding up?
  29. Sep 25, 2020 at 2:11 PM
    I wouldn't do textured like that. Use SEM trim paint 39143. Check out @2020Platinum and how he did his. He also has videos on the removal process. :thumbsup:
  30. Sep 25, 2020 at 2:14 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    I'll check them out
    I used 2020s video for removing it a few weeks ago, but I already got a small chip in my Plastidip.
    I'll probably do paint next time. At least I'm comfortable taking it apart now.
    2020Platinum likes this.
