Paint bubble on door
Discussion in '3rd Gen Tundras (2022+)' started by Jeffro18, Jan 22, 2025.
  1. Jan 22, 2025 at 9:16 AM
    Jeffro18
    Jeffro18 [OP] New Member
    Jeffro
    2025 Blueprint 1794 TRD
    Hi All - Just washed my new 2025 Tundra and found a bubble on the lower panel of the passenger door. Went back to Toyota and they took pics and have approved a repair. I don't know what the repair involves as I have not been contacted as to when/how it will be fixed. Just curious is anyone else had this issue.
    2025 Blueprint 1794 TRD Off Road edition.
    -Jeff
  2. Jan 22, 2025 at 10:24 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    repaint would be the fix
  3. Jan 22, 2025 at 12:05 PM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    :worthless:
    ZappBrannigan likes this.
  4. Jan 22, 2025 at 12:21 PM
    Depends. If it’s a bubble of paint as in separated from the metal, then repaint. If it’s a run, then potentially a cut and buff and reclear.
    and……
    :worthless:
  5. Jan 22, 2025 at 12:32 PM
    Hella Krusty
    Hella Krusty New Member
    Spider eggs under the paint waiting to hatch
  6. Jan 30, 2025 at 5:47 AM
    Jeffro18
    Jeffro
    Sorry - here’s the paint bubble. Toyota said they’ll repair it just waiting for when.
    Tundrastruck91 likes this.
  7. Jan 30, 2025 at 5:49 AM
    TexasCabledawg
    TexasCabledawg New Member
    2024 Land Cruiser (had a ‘22 Tundra)
    Pop it, rub salve on it and let it heal.
    75tranzam and Tundra family like this.
  8. Jan 30, 2025 at 5:55 AM
    If that’s as small as the images make it look, I would not want my door repainted to repair it. Just cut it down, and touch up whatever needs it after. You’ll retain 99% of the factory finish on that panel. It’s down in the chipguard anyway.
  9. Jan 30, 2025 at 5:58 AM
    Jeffro18
    Jeffro
    That's what I'm thinking - pop it or shave it down to keep as much factory integrity to the paint job.
  10. Jan 30, 2025 at 8:05 AM
    Rockpig
    Rockpig You did what?
    08 Limited
    Better find out what the fix is before they do it. They'll send it to a body shop that won't texture it correctly if they try to blend it. As others say, shave it down and hit it with touch up paint.
  11. Jan 30, 2025 at 8:32 AM
    Jeffro18
    Jeffro
    Thanks for everyone input - I'm going to ask what they plan on doing prior and ask for it to be shaved down and touched up.
  12. Jan 30, 2025 at 8:40 AM
    AZBoatHauler
    So.Arizona
    You’re more understanding than I am. If I purchased a $75k vehicle with bubbled paint I’d be asking for a new door with OEM paint.
    vtl likes this.
  13. Jan 30, 2025 at 9:19 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    If the fix is not the new door then leave it as is. Failed integrity of paint is rust reason number one.
  14. Jan 30, 2025 at 9:24 AM
    Breathing Borla
    Northern Illinois
    is the aluminum going to rust?
    1lowlife likes this.
  15. Jan 30, 2025 at 9:31 AM
    AZBoatHauler
    So.Arizona
    Probably not but it will oxidize and likely shed more paint.
  16. Jan 30, 2025 at 9:38 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Is it aluminum? Yea, it will oxidize in presence of road salt. Also it is attached to steel parts, which makes a good pair for electrochemical corrosion. I don't dare to say the brand name, but mine is 20 years old, I see this type of corrosion where aluminum is involved. Aluminum plays sacrificial anode role. So partially aluminum vehicle is not fully rust proof.
    Paint will begun chipping away.
    AZBoatHauler likes this.
  17. Jan 30, 2025 at 9:44 AM
    Breathing Borla
    Northern Illinois
    KNABORES and AZBoatHauler like this.
  18. Jan 30, 2025 at 9:46 AM
    AZBoatHauler
    So.Arizona
  19. Jan 30, 2025 at 10:13 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
  20. Jan 30, 2025 at 10:22 AM
    I bet it sounds like lady parts….
  21. Feb 17, 2025 at 6:37 AM
    Jeffro18
    Jeffro
    Dropped it off and hoping the fix goes well. I’ll post up some pics when I get it back
  22. Feb 17, 2025 at 6:43 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    A friend dropped his Lexus for repair at body shop used by dealers. Repair involved a repainting one side. Well, the color matches, more or less, however the clean room was not very clean and there's a lot of dust particles embedded in the paint now. The friend does not care, but high chance you will end up with more imperfections on the paint than you had before the repair.
    The factory paint is the best.
  23. Feb 23, 2025 at 1:36 PM
    Jeffro18
    Jeffro
    So just got my truck back and here's the result....not the greatest and in photos it's easier to see with some editing.
  24. Feb 23, 2025 at 2:21 PM
    If a professional paint shop did that, they suck. It’s not that noticeable though from a few feet I bet. As long as it doesn’t bother you and it’s protected from corrosion, all good.
    Breathing Borla likes this.
