Paint and texture in mobile home
Discussion in 'Home Improvement' started by dfvdsff, Dec 5, 2022.
  1. Dec 5, 2022 at 10:55 PM
    dfvdsff
    dfvdsff [OP] New Member
    Aerty
    2017 Black Tundra
    I am wanting to paint the walls in my mobile home. The walls are vinyl over gypsum (VOG) wallboard with batten strips over the joints. I was wondering what the best way to texture and then paint would be.
    Should I leave the battens in place or remove them and texture and paint them seperately? I initially thought I would leave the batten strips in place but I was worried that I would get a "crack" between the batten and the wallboard. Any thoughts on this?
    Is it possible to do it by myself or I should go with any professional painter?
    Your thoughts?
  2. Dec 5, 2022 at 10:58 PM
    dfvdsff
    Aerty
    2017 Black Tundra
    Suggestions will be highly appreciated.
  3. Dec 5, 2022 at 11:00 PM
    dfvdsff
    Aerty
    2017 Black Tundra
    I forget to add that I'm based in Calgary, Canada.
  4. Dec 6, 2022 at 2:28 AM
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    I've never seen VOG textured. I would assume it could be done. Try the ever magical YouTube. It's amazing what you find on it.
    bflooks likes this.
  5. Dec 6, 2022 at 4:54 AM
    mnm
    mnm Old Guy...
    Mark
    Smithfield, VA
    2008 Tundra Limited 4x4 DC
    I just primed and painted mine. Did not remove the batten strips because I don't think I can get a good result filling in the gaps. It looks sooooo much better just with the paint job. Been about 5 years ago and it is still like the day I painted it.
    ATV25 likes this.
  6. Dec 6, 2022 at 5:30 AM
    Think the key will be a quality primer coat. Then the texture (would keep it light) would be able to stick to that. Then paint. Obviously don’t expect new construction fresh sheet rock results, but you can probably get it looking pretty good. Be sure to clean the vinyl wall covering well before primer application.
    ATV25 likes this.
