Pads and shoes are fine but still squealin?
Discussion in '1st Gen Tundras (2000-2006)' started by Desrat, May 16, 2021.
  1. May 16, 2021 at 10:32 AM
    Desrat
    Desrat [OP] New Member
    AZ
    06 Double Cab RWD V8
    Howdy y'all. I noticed my brakes were sqeualin like a hog (really only in reverse under light brake application) and figured they were reaching end of life.
    Bought the truck with 133k and have put 18k miles on it, so I figured it's probably time. Ordered parts for front and rear.
    Turns out I have plenty of pad in the front and shoe in the rear. More than 3x the minimum (1/16"). Discs and drums look good -- no deep scratches or grooves. Hosed them down with brake cleaner.
    Any advice on what I should look at next? Should I just ignore the squeaking?
  2. May 16, 2021 at 10:43 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Is it the front or rear making noise? Those pins look dry, should have some lube on them and they can certainly make noise when dry or corroded.
    Desrat[OP] likes this.
  3. May 16, 2021 at 10:50 AM
    Desrat
    AZ
    I think It's the rear, but I will try putting a little brake grease on those.
    I don't really think about corrosion much since this truck has been in the southwest all it's life, I'm fairly sure
  4. May 16, 2021 at 10:57 AM
    frichco228
    Toyotas are famous for squeaks, squeals when backing up. Usually first drive backing out of the driveway, then it goes away. If it is making noise all the time then I would try lubing any of the brake parts that need lube.
  5. May 16, 2021 at 11:20 AM
    Professional Hand Model
    Hand Protectors
    Lube 2 pins on both front calipers. Also, lube back of Pads.
    Main noise suspect: Rear Brakes.
    Put lube on the points where your rear shoes contact the backing plate. There is a short cut you can do if you don’t want to remove the shoes. Take a popsicle stick and put a little Silglyde on it and then pull ever so slightly the shoe away from the backing plate just enough to fit the popsicle stick between the two and apply a dab at the contact zone(s). Think there are 5 per shoe.
    FrenchToasty and Desrat[OP] like this.
  6. May 16, 2021 at 11:42 AM
    Desrat
    AZ
    Good trick, now I just need to find a popsicle. I don't want to pull the shoes off if I'm not even going to replace em.
  7. May 16, 2021 at 11:50 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Publix has banana flavor on sale, box of 12 for $2.99
  8. May 16, 2021 at 11:54 AM
    Desrat
    AZ
    Now THIS is the answer I needed!!!
    bmf4069 and BubbaW[QUOTED] like this.
  9. May 16, 2021 at 11:56 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Ew
  10. May 17, 2021 at 4:52 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    What kind of prep work does the popsicle stick need? I guessing remove the frozen treat first?
  11. May 17, 2021 at 4:54 AM
    Hand Protectors
    You can actually buy them in packs an make your own Frozen Organic Treats.
    bmf4069[QUOTED] likes this.
  12. May 17, 2021 at 1:44 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Small to medium flat tip screwdriver will also work.
  13. May 17, 2021 at 2:05 PM
    Desrat
    AZ
    I believe you will want to leave the frozen fruit on the stick and apply it to the whole brake system for lubrication
