padle shift?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Nighthawk, Apr 2, 2020.
  1. Apr 2, 2020 at 11:39 AM
    Nighthawk
    Nighthawk [OP] New Member
    Keith
    Frederick Md.
    2018 Tundra Limited crewmax
    linex bed Truxedo Pro F-15 Tonneau,Weathertech mats,TRD exhaust,Matt Geckco bed lights,hood light,shorty antenna, all LED lights inside, Fomoto oil drain valve,
    Prob. a dumb Question Anybody know if there is a Paddle shift kit for 3rd Gen?
    Newbie_19 and CMB like this.
  2. Apr 2, 2020 at 2:51 PM
    Not to my knowledge.
  3. Apr 3, 2020 at 2:48 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    From the number of Tundra owner's who 'dare' to use the Sequential Shifter, I doubt it would pay anyone to offer it.
    Newbie_19 likes this.
  4. Apr 4, 2020 at 6:17 PM
    Nighthawk
    Keith
    Frederick Md.
    I thought it would be more convenient to have at Fingertips
    rebmo likes this.
  5. Apr 4, 2020 at 6:43 PM
    906UP
    906UP New Member
    My Camry has it, I used it once to see if it works, that was it.
    TacomaLC likes this.
  6. Apr 4, 2020 at 6:44 PM
    My Lexus has it. I never use it
  7. Apr 5, 2020 at 2:40 AM
    CMB
    CMB New Member
    Cecil County MD.
    You're right but only for the VERY few Tundra owner's, who'll ever use the feature. I certainly would, I haven't driven my truck in "D" for several years. Wait till the 10 speed transmission is offered in the 2022 Tundra. I can't imagine how many- "my Tundra shifts too much" posts there will be!:rolleyes: Read a rumor about a six speed standard transmission being offered too.If nothing else, it'll be a great Anti-Theft Device!
    BravoDeltaRomeo likes this.
  8. Apr 5, 2020 at 10:17 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Paddle shift first appeared on high performance cars. Paddle shifters allowed you keep both hands on the steering wheel while running through gears on curvy tracks, without any loss of attention using one hand to fiddle with the shifter handle. Since the Tundra is more of a straight line racer, I'm thinking a supercharger probably should be your first priority.
    I think the first paddle shifters were actually on manual gearboxes that shifted automatically (Porsche? BMW?). Then they started putting paddle shift on automatic transmissions which was a much easier and intuitive application. The feature on an automatic transmission is also like kissing your sister compared to running through the torque curve shifts with a manual transmission.
    Tundra has the Sequential Shifter, which really limits the highest gear the transmission will shift to. Of course, you can select a low gear and blip the shift handle to "shift" through the range like a manual transmission, but what's the point? Why not let the transmission do the same job better?
  9. Apr 5, 2020 at 10:31 AM
    CMB
    CMB New Member
    Cecil County MD.
    If you've ever driven on a hilly,curvy 30-35 mph road in D,while paying attention, you'd see the tach react and feel the constant shifting on an unlocked torque converter. Choosing the correct gear that prevents this needless shifting, is one reason the Sequential Shifter is there.
  10. Apr 5, 2020 at 10:55 AM
    NOLA Tundra
    NOLA Tundra Sandbagging
    Jesse
    2019 Quicksand CM
    3” level leds all around Morimoto headlight and fog light bulbs Flowmaster American Thunder
    It also sounds badass if you have exhaust when you get it up to about 4-5K and let of the gas and cruise.
  11. Apr 5, 2020 at 12:00 PM
    JohnLakeman
    Since I live in the "Texas Hill Country", I first became aware of the constant shifting on the drive home after delivery. I discovered I can place the Sequential Shifter in 4th and that eliminates excessive shifting into and between overdrive gears on hills at highway speeds. But...that also raises engine rpm overall and decreases fuel efficiency. I decided to quit thinking about it and let the transmission do it's thing in "D".
    By selecting the top gear to be shifted into, the Sequential Shifter permits the driver to limit the highest gear to keep the engine high in the power band for the speed the truck is traveling. For example, when slogging through mud or snow at low speed, you want rpm up and the transmission staying in a lower gear. Depending on how fast you're going, 2nd or 3rd might be a good choice.
    Nighthawk[OP] likes this.
