PA speaker not loud
Discussion in 'Electrical' started by Flockem, May 28, 2022.
  1. May 28, 2022 at 4:18 PM
    Flockem
    Flockem [OP] New Member
    Remington
    2016 Crewmax 4x4
    6112/5160 +CB shims SPC UCA and Diff Drop Toytec Shackles 35x12.50 BFG ATs on factory 20s Spidertrax 1.25s BMC Headlight Revolution SM LED Breather Mod Dents in the body due to trees...
    So bought this PA speaker
    All-Weather Mono Trumpet Horn Speaker - 5” Portable PA Speaker with 8 Ohms Impedance & 25 Watts Peak Power - 180 Degree Swiveling Adjustable Bracket for Easy Maneuverability - Pyle PSP8 https://www.amazon.com/dp/B001D0LMG2?_encoding=UTF8
    set it up on a Uniden Bearcat and when you turn on the PA function the static is loud. You turn up the squelch and the static goes away… but the speaker isn’t very loud…. Any thoughts?
    I can hear the static just fine but when I talk it’s not there….
