P2445
Discussion in '1st Gen Tundras (2000-2006)' started by Bks service, Jan 28, 2023.
  1. Jan 28, 2023 at 12:30 PM
    Bks service
    Bks service [OP] New Member
    Brandon
    2005 silver 4.7
    None
    Need help please.
    Working on an 05 tundra 4.7. I have replaced the air pump, the check valve, the air driver module, and the air pump fuse. I’ve checked all the wiring and connections. Is there a possible problem in the ecm?
    Tia.
  2. Jan 28, 2023 at 2:20 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Can't offer much more than questions....What caused you to change pump, same initial code ?
    Are you in cold climate ?
    Secondary Air Injection System Codes: Toyota & Lexus | Hewitt Tech (hewitt-tech.com)
  3. Jan 28, 2023 at 3:42 PM
    Bks service
    Brandon
    2005 silver 4.7
    None
    Truck went into limp mode, scanned it, and it had multiple air injection codes. Removed intake and the pump was locked up. Changed pump and check valve.
    Ram good for about a 100 miles, and then into limp mode again.
    Scanned again and found p2445 and po418. Replaced air driver module and air driver fuse. Truck again ran fine for about another 100 miles. Then limp mode again.
    Scanned and p2445 is back.
    yes I am in a cold climate.
  4. Jan 28, 2023 at 5:37 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Did you read the Hewitt article I linked to ?
    Perhaps it is a coincidence but their speaking of your exact issue.
    Hmmm....could have swore you had P0418 also in thread title when you initially posted which others might have been helped by !
    shifty` likes this.
  5. Jan 29, 2023 at 6:23 AM
    Bks service
    Brandon
    2005 silver 4.7
    None
    Thanks for your help. Going to put the truck back together today and give it back to the customer, and explain that when it happens again I’ll have to do the Hewitt bypass.
    Thank you for your help.
    BubbaW likes this.
  6. Jan 29, 2023 at 4:50 PM
    Or you could advise them to check on the proper fix, which would be contacting a dealership and asking if they can re-flash the ECU.
  7. Jan 29, 2023 at 5:58 PM
    Bks service
    Brandon
    2005 silver 4.7
    None
    I called a local dealership, and they told me there’s not a reflash. They told me bring the truck in, so they could look at it.
    You know what that means $$$$$$
    shifty` likes this.
  8. Jan 29, 2023 at 6:00 PM
    Yup, they don't call it a stealership for nothing...
    Another option that's not horribly expensive, if you have the p/n off the ECU, you could look into swapping it out.
    https://www.fs1inc.com/
    They sell reflashed ECU, although I'm shocked the dealership won't do it. It's not like they don't have the ROMs or whatever they can burn into the ECU. Surely they can get them.
    xerox likes this.
