P2442/P2447-2008
Discussion in '2nd Gen Tundras (2007-2013)' started by Knolls67, Dec 3, 2019.
  1. Dec 3, 2019 at 6:48 AM
    Knolls67
    Knolls67 [OP] New Member
    Well it happened, raining like hell for two days and the SAIS went shit, just wondering what kind of luck people have had with the Hewitt bypass kits??
  2. Dec 3, 2019 at 6:50 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Don't think bypass kits only work if the faults aren't active in the ECM? Meaning the bypass kit needs to be installed before an issues arises. I could very well be wrong, but somehow I thought that's was I heard.
  3. Dec 3, 2019 at 7:38 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    Nah, you just need to install the bypass, clear the codes (with scanner, etc or even unhook the battery for 30mins-1hr) and you're good to go.
    At least, that's what I did for my P02440
    MacCTD likes this.
  4. Dec 3, 2019 at 7:44 AM
    Knolls67
    Ok, just wanted to get some input before ordering the bypass, really not looking forward to pulling the intake to remove all the SAIS shenanigans haha
  5. Dec 3, 2019 at 10:36 AM
    Obtunded
    Obtunded New Member
    San Antonio
    2016 Tundra CrewMax XPS-X 4x4
    Carbon fiber dash, leather seats
    I have an 08 CM that I put the Hewitt kit on after my ais valve was stuck. The kit worked great. Immediately got out of limp mode. I do still have some flashing lights on, ABS, VSC, and slip control. Other than that my truck works fine. I'd get it if you need it. Only if you're out of warranty.
  6. Dec 3, 2019 at 11:39 AM
    Knolls67
    You mean to tell me I can get rid of the SAIS and all the TC shit in one shot!?
  7. Dec 3, 2019 at 12:17 PM
    Obtunded
    Obtunded New Member
    San Antonio
    To me it was worth it. Toyota wanted over 2k to fix it cuz it was out of warranty. I bought it for 160 something and had my power back in no time flat. There are other things I'm dealing with now but, im still happy with my tundra.
  8. Dec 3, 2019 at 12:18 PM
    Obtunded
    Obtunded New Member
    San Antonio
    It might help the TC. do a zero point and see what codes you get after
  9. Dec 3, 2019 at 12:20 PM
    MacCTD
    MacCTD New Member
    2010 CM 4x4
    5100s
    Same here on my 2010, has been well for a while now.
  10. Dec 4, 2019 at 4:42 PM
    Knolls67
    So i just came across another company that makes the bypass kits as well, RuTech, prices seem to be much cheaper but haven't made it through any reviews yet
  11. Dec 4, 2019 at 6:18 PM
    Lifeislarge
    Lifeislarge New Member
    2007 Tundra 4X4 TRD 5.7L
    I went for the Hewitt plug and play option and it worked perfectly. $190 to never have to worry about that crap again is well worth the dough. Install took me 40 minutes including the blocking plates on the tubes. Make sure you hook it up to the right post on the starter relay or it will set codes again on the first cold start. Get a code reader and delete the codes before install.
