P2440 Code
Discussion in '2nd Gen Tundras (2007-2013)' started by Arts1toytun, May 30, 2022.
  1. May 30, 2022 at 1:26 PM
    Arts1toytun
    Arts1toytun [OP] New Member
    Art
    2008 Toyota Tundra
    My 2008 Toyota Tundra has 88333 miles. Drive it occasionally, a week at a time every 2 months. Haven't driven it for about 4 months this time. Started it up and the "VSC Off" light was flashing and the "Slip Indicator Light" was on. I drove it for about 2 hours and nothing changed. Connected the OBD II reader and got the P2440 code plus "Sec.Air Inj.System Switching Vlv Stuck Bank 1."
    I tried several options to clear the the "VSC Off" message but none worked. I read up about the valve sticking and watched some YouTube videos. My questions are these:
    1) Does all this mean my ECM Module is bad since all this happened at the same time?
    2) Would the stuck valve give all these indicators?
    3) If so, can the valve be repaired, or do I have to buy a new one?
    Thank you.
  2. May 31, 2022 at 7:53 AM
    Arts1toytun
    Art
    2008 Toyota Tundra
    I forgot. The "Check Engine Light" was on as well.
  3. Jun 2, 2022 at 1:24 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
  4. Jun 5, 2022 at 8:21 AM
    Landodnal
    Landodnal New Member
    Ryan
    2008 Toyota Tundra Limited Slate Grey 4WD
    2" Leveling Kit
    Hi Arts1toytun. I just posted a write up on the replacement of the secondary air intake valve today. You should check it out. It may answer some of your questions. Mine went bad last week, so I replaced it. I had just stopped driving my truck regularly because I bought a small car. I went to move the truck and the check engine light was on. I don't think sitting is good for these valves.
  5. Jun 7, 2022 at 6:31 AM
    Arts1toytun
    Art
    2008 Toyota Tundra
    Last week I read a post somewhere about clearing the codes and it worked. So, I cleared the codes and have driven it about 8 times, putting on about 150 miles. The power returned and no codes have shown up at this time. If they return, I will return to these postings. Thanks for all your help.
  6. Jun 7, 2022 at 9:15 AM
    Dr. Goesinya
    Dr. Goesinya New Member
    2011 Tundra 4x4 Crew Max
    N/A
    What engine does your Tundra have? I had this same issue with my 4.6 and I had the by-pass kit already on it. I bought a Dorman replacement part, took about 3 minutes to swap out and no more codes and dashboard is clear. You should also purchase the by-pass kit as it will help this happen again in the future. Clearing the codes will not work for this as water has already made it into that part and
    HewittTech01 likes this.
  7. Oct 5, 2022 at 6:57 AM
    HewittTech01
    HewittTech01 Dont Replace SAIS, Bypass It!
    Lexington, SC
    Secondary Air Injection System Bypass Kit
    Thanks again to all for recommending the Bypass Kit! I posting some recent threads below anyone else coming across this thread with SAIS issues. @Arts1toytun If you have any question do not hesitate to contact us.
    What Does the Secondary Air Injection System Do?
    https://www.tundras.com/threads/what-does-the-secondary-air-injection-system-do.113683/
    What Do My Secondary Air Injection Error Codes Mean?
    https://www.tundras.com/threads/what-do-my-secondary-air-injection-error-codes-mean.113686/
    How to Fix Secondary Air Injection System?
    https://www.tundras.com/threads/how-do-you-fix-the-secondary-air-injection-system.113688/
