P2440, 2441 etc.
Discussion in '2nd Gen Tundras (2007-2013)' started by Koynoel75, Nov 2, 2019.
  1. Nov 2, 2019 at 7:42 AM
    Koynoel75
    Koynoel75 [OP] New Member
    Elly
    P2440, 2441, etc.
    My 2008 tundra giving me head stress..
    I'll change both 2ndary injection valve,, because its corrosion and wet,, still Engine and VSC blink light on. So i replaced air pump motor,, but the engine and VSC stil light on,, try to reset its use less .. overnight cold start morning light come on again..
    Is it the BYPASS my next better option..
    Pls comment..
  2. Oct 5, 2022 at 7:33 AM
    HewittTech01
    HewittTech01 Dont Replace SAIS, Bypass It!
    Lexington, SC
    Secondary Air Injection System Bypass Kit
    @Koynoel75 The most expensive option is taking it to the Dealership and replacing with Factory/OEM Components. On average, most Dealerships will quote between $2,000 – $3,000 for parts and labor. Depending on your engine size, you may need to replace both Air Switching Valves and could involve removal of the intake. However, replacing the Air Switching Valve only partially addresses the Secondary Air Injection System and even worse may only be temporary. This option does not prevent the other Air Pumps or Valves from failing or even guarantee the new Air Switching Valve from failing again in the future.
    We are more than happy to answer any question you may have about the Hewitt Technologies SAIS Bypass Kits. I have also included some additional resources for any one looking for more information about this issue.
    What Does the Secondary Air Injection System Do?
    https://www.tundras.com/threads/what-does-the-secondary-air-injection-system-do.113683/
    What Do My Secondary Air Injection Error Codes Mean?
    https://www.tundras.com/threads/what-do-my-secondary-air-injection-error-codes-mean.113686/
    How to Fix Secondary Air Injection System?
    https://www.tundras.com/threads/how-do-you-fix-the-secondary-air-injection-system.113688/
