P1126 Error Code (Magnetic Clutch Circuit)
Discussion in '1st Gen Tundras (2000-2006)' started by Sunjester, Oct 22, 2022.
  1. Oct 22, 2022 at 8:34 PM
    Sunjester
    Sunjester [OP] New Member
    2001 Tundra SR5
    I've seen a number of posts in the forum related to a P1126 error and it seems like it is a catch all code. I have a 2001 Tundra, 4.7 with 190,000 miles. The truck has been well cared for. I recently got a check engine light with a P1126 error code, and it states Magnetic Clutch Circuit. The truck is running fine; no startup or power issues. In another thread someone suggested either the crank or cam sensor as a possible cause. I had a new timing belt put on last year about 5,000 miles ago, and I swapped out the crank sensor after this error but no luck. I didn't think either of those could be the issue because if one or the other was bad, I would expect to see timing issues while the truck is running. Does anyone have any other suggestions? Image of the error code below.
  2. Oct 23, 2022 at 8:42 AM
    shifty` I'm having daydreams about night things
    Something with the throttle body/assembly would be my guess.
    Meanwhile, here are two things to help you - a link to the FSM for '00-'03 Tundras, and I'm also attaching the FSM diagnostic flow for that DTC in PDF format. I recommend you tap the down arrow to download the FSM after clicking the link, then download the diagnostic PDF and walk through it.
    Sunjester[OP] likes this.
  3. Oct 23, 2022 at 8:44 AM
    PS - I know this is a stupid observation, but I'm glad you mentioned the timing belt change 5k miles ago. 5k miles is just about the amount of time for something to either wiggle loose, or for a pulley to cut through an improperly secured wire harness. I would look very closely from above and below at all wire harnesses anywhere near a pulley for damage. I'd also look at and consider jiggle or possibly unplug/replug connectors on the front & top end of the engine, especially around the throttle body assembly.
  4. Oct 23, 2022 at 6:03 PM
    Sunjester
    2001 Tundra SR5
    Thanks, I'll check into those suggestions.
  5. Nov 25, 2022 at 8:16 AM
    Sunjester
    2001 Tundra SR5
    Well, I guess I'm going to start hunting gremlins, probably in a vacuum line somewhere. I swapped the mass airflow sensor. No change. I can clear the alarm but as soon as I turn the engine off and restart it, the check engine light comes back. Any other suggestions?
  6. Nov 25, 2022 at 8:18 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    What brand mass air flow sensor?
  7. Nov 25, 2022 at 8:47 AM
    Sunjester
    2001 Tundra SR5
    I don't remember. I replaced it a few weeks ago but have been busy with work travel since then. It was the suggestion from my local Toyota tech. Is there a preferred brand?
  8. Nov 25, 2022 at 8:49 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Hitachi for the V8 trucks. You should be able to find one on Rock Auto.
    Here's a link.
    https://www.rockauto.com/en/moreinfo.php?pk=3020256&cc=1357938&pt=5128
    Sunjester[QUOTED][OP] likes this.
  9. Nov 25, 2022 at 8:51 AM
    Sunjester
    2001 Tundra SR5
    thanks
    Tundra2 likes this.
