P106b and p2444 air pump and pressure sensor codes
Discussion in '2nd Gen Tundras (2007-2013)' started by Gto7419, Apr 18, 2021.
  1. Apr 18, 2021 at 6:05 PM
    Gto7419
    Gto7419 [OP] New Member
    2010 Tundra
    P106b indicates one pressure sensor is reading differently than the other two. P2444 indicates secondary air pump is stuck on bank 1.
    Any additional insight as to what I'm dealing with here?
    Thanks!
  2. Apr 18, 2021 at 6:44 PM
    Pomp_Cat115
    Pomp_Cat115 New Member
    Los Angeles, CA
    Your aip system. Look up the hewitt aip bypass kit.
  3. Apr 18, 2021 at 7:00 PM
    Gto7419
    2010 Tundra
    Yup, I've been there. Curious why the sensor code is coming on with the pump code and not the valve code. Either way I think it looks like I'm spending $400. Is Hewitt a vendor on here?
  4. Apr 19, 2021 at 7:11 PM
    Gto7419
    2010 Tundra
    Anyone have any additional info on this? Most people with AIP issues get codes related to the valves. I am not getting that here...
  5. Apr 22, 2021 at 11:53 AM
    AnthonyC
    AnthonyC TAKE IT EASY WHILE YOU"RE GOING FAST
    Anthony
    Virginia Beach, VA
    2010 Tundra SR5 TRD DOUBLE CAB
    TRD DUAL EXHAUST, FIRESTONE AIR BAGS
    Yes I had an issue. The check valves under the intake manifold at the rear of the engine was stuck open due to water getting in the snorkel tube. Right front wheel well there’s two air pumps, I replaced both to no avail. I had it checked further by a good technician in Spring Hill, fl. While I was visiting family. According to the technician, Toyota warranties the check valves for ten years, or 150,000 miles. Mine expired October,2019
  6. Apr 22, 2021 at 1:22 PM
    Gto7419
    2010 Tundra
    Thanks. This code is for a pressure sensor and and a pump staying on. The p2444 is apparently a very rare code. Either way I need a bypass kit or I have to replace pumps and valves.
  7. Apr 23, 2021 at 12:35 AM
    AnthonyC
    Anthony
    Virginia Beach, VA
    Sorry for your misfortune, but very glad I could help.
