P0894
Discussion in '2nd Gen Tundras (2007-2013)' started by blackdemon_tt, May 27, 2021.
  1. May 27, 2021 at 12:32 PM
    blackdemon_tt
    blackdemon_tt [OP] Battery Slayer
    Hello all,
    Edit: 07 Tundra 5.7l 231k 2wd
    Well, I hit a snag today... I got a p0894 code, referencing transmission component slipping.. Was supposed to make a run to Petaluma today, but this blindsided me today.. It started at a stop light... once I hit the accelerator there was a slight delay and a heavy pedal feeling and a surging acceleration past 2.2k rpm. It is very similar to a clutch starting to go. Where you can accelerate then 3k rpm and it will catch and it will go to the moon. After acceleration and shifting appears to be ok... just initial acceleration... no apparent leaking, fluid change has been awhile.. maybe I'll start there. Any help is appreciated.
    Thanks in advance
    Edit: Here is some continuation to my transmission issues.
    I think a rodent got me. Transmission and engine codes. | Toyota Tundra Forum (tundras.com)
  2. May 27, 2021 at 12:38 PM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    Can you produce the same results if you manual shift?
  3. May 27, 2021 at 1:26 PM
    Notarobot
    Notarobot Jagged lines!
    2013 CM
  4. May 27, 2021 at 1:37 PM
    blackdemon_tt
    Actually forgot to mention that. Yes I tried and It appears to accelerate fine in 1st geat manual shift... may need to override 1st gear that way, as I did some testing while closer to home... but if manual mode in "6th gear" it will do the same hesitation in both "manual" and "D"... if I drop it to 1st it appears to be OK...
  5. May 27, 2021 at 1:40 PM
    blackdemon_tt
    That was my main thought, except I was focusing on the flexplate, you just reminded me that they are usually bolted together.... This is something else I found, more specific on the Tundra
    http://www.ttundra.com/1068/transmission_component_slipping_p0894_p2714_.html
    P0894
    The ECM detects a malfunction in shift solenoid valve SLT, S1, S2, S3, S4 or SL2, or the 1-2 shift valve, or an incorrect gear 6 ratio according to the difference in speed of the turbine and output shaft, and also by the oil pressure (2-trip detection logic).
    • Shift solenoid valve SLT remains open or closed
    • Shift solenoid valve S1, S2, S3, S4 or SL2 remains open or closed
    • Gear 6 incorrect ratio (sequence valve) or 1-2 shift valve is stuck
    • Valve body is blocked
    • Automatic transmission (clutch, brake, gear, etc.)
    SRT-1 likes this.
  6. May 27, 2021 at 1:52 PM
    Dr Doobie
    Talkeetna,Alaska
    If there's no leaks i would check condition of fluid.
    Maybe there's a transmission expert that will chime in with suggestions.
    When it comes to internal transmission problems, we're getting above my pay grade.lol
  7. May 27, 2021 at 2:11 PM
    blackdemon_tt
    I'll have to check fluid tomorrow, as I'm at work right now... LOL.
    Dr Doobie[QUOTED] likes this.
  8. May 27, 2021 at 3:43 PM
    blackdemon_tt
    Got a full box of WS transmission fluid I was going to exchange a couple months ago, but forgot due to unforeseen circumstances.... may swing by the stealership and snag more..
  9. May 27, 2021 at 4:43 PM
    Notarobot
    2013 CM
    Yes, the flex plate is usually bolted between the crank and TC.
  10. May 27, 2021 at 6:28 PM
    blackdemon_tt
    MMMM I think I may be too late, but IDK??? I found a TSB, but not sure it its valid. It appears to be a C1 Clutch damage, and I will post this up here.. It appears as if my transmission is gone.....
  11. May 27, 2021 at 6:54 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    Sequential Shift isn't a true manual mode, if I lock my truck in 4th gear (I have a 5 speed auto) to prevent it from going into overdrive while towing, itll still shift down to 3,2, and 1, and it will shift up to 4 while taking off, but it will not shift to 5. Its like a lockout for how high the trans can shift. So if you select 1st gear, it'll lock the trans in 1st gear because there isn't a lower gear for it to shift to. It essentially gives the tundra an overdrive off button while also having sequential shifting.
    (this is how it was described to me from my boss at our mechanic shop, hes been working for 30 years so I hope he has a lick of intelligence)
  12. May 27, 2021 at 6:55 PM
    joseph_womack
    Joe
    Louisiana
    Also, maybe Valvoline or Mobile 1 or another company makes an anti slip additive to transmission fluid that you could try out for starters, along with the fluid change
  13. May 27, 2021 at 7:44 PM
    blackdemon_tt
    Yes, definitely will go for an oil change first... TSB stated that first before replacing the trans... but will add anti slip additive to the trans to see for a difference... I'm hoping this will help, but if all else fails, I guess I'll have to make a decision between replacing the truck or replacing the transmission, or having it rebuilt... I've looked up a few vids that appear to be bushings being worn down, but I wont know until I pay someone for a teardown..
    and for the manumatic, yes I understand it that way as well... I know it wont stay in any shift except for 1st... It makes it easier to explain... I will hit up Toyota corporate referencing the TSB, I doubt it'll be covered, but its worth a shot.....
    joseph_womack[QUOTED] likes this.
  14. May 27, 2021 at 8:46 PM
    joseph_womack
    Joe
    Louisiana
    Good luck man! I hope for the best!!
  15. May 27, 2021 at 9:14 PM
    blackdemon_tt
    Thanks
    joseph_womack likes this.
  16. May 28, 2021 at 5:41 PM
    blackdemon_tt
    Ran a full diagnostics and found a 2nd code buried.. p2714 predsure control solenoid D performance or stuck off....
  17. May 28, 2021 at 9:28 PM
    joseph_womack
    Joe
    Louisiana
    Ah, so looks like that might be where your problem lies...
  18. Jun 2, 2021 at 9:06 AM
    blackdemon_tt
    So, I haven't done shit the last few days.. I have parts on order, a strainer, strainer gasket and oil pan gasket.. had to use the slower more expensive dealer, cuz I fucked myself from the one I liked...
    I have driven it about 20 miles around town as I need it and have not had any issues.. it engages immediately and shifts perfectly.. I'm waiting on parts to do an oil change and a full flush, got 15 quarts ready to go.. will update once I'm done.
  19. Jun 19, 2021 at 1:34 PM
    blackdemon_tt
    Finally got around to doing a drain and fill, and it was dark AF, but gladly didn't smell burnt... smelled like ol gear oil... shifts smooth like butter..... plus found a leak.. not sure how long do I have..... my water pump is leaking... that's totally new....
    Mind the belt... it's my 5th
  20. Jun 19, 2021 at 8:29 PM
    joseph_womack
    Joe
    Louisiana
    so all your transmission problems have been fixed?
  21. Jun 20, 2021 at 8:03 AM
    blackdemon_tt
    It appears to be that way.. I was reading a thread on performance stuck code along with a drain and fill... and apparently it is due to low or high transmission fluid. Eitherway i noticed jumpy shifts between 1 and 2 along with some hanging after the drain and fill it has been smooth as ice so far.
  22. Jun 20, 2021 at 8:24 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Hope you are out of the woods for sure.
    Did you use a friction modifier or just drain and fill?
  23. Jun 20, 2021 at 8:34 AM
    blackdemon_tt
    Just drain and fill...
    Next week I'm dropping the oil pan, strainer and checking out the insides. Next time I will be using the friction modifier since I did purchase a bottle and its hanging out with the other ATF fluid and parts.
  24. Jun 20, 2021 at 10:07 AM
    joseph_womack
    Joe
    Louisiana
    sounds good, glad that fixed your problems!
  25. Jun 20, 2021 at 10:24 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    Be aware that most of the pan bolts go up and through the pan and stick out the back. They are a bitch to get out because you'll be pulling rust through with them. I have dropped the transmission pan and cleaned/replaced the filter on every single used car I've ever bought except the Tundra, as it just doesn't seem worth it!
    blackdemon_tt[OP] likes this.
  26. Jul 30, 2021 at 5:13 PM
    2016ToyTun
    2016ToyTun New Member
    Jon
    2016 MagGrey DC TRD Off-road
    Just did this today. Hope it works.
  27. Jul 30, 2021 at 5:40 PM
    blackdemon_tt
    Cool... I'm having other issues, hoping it's not transmission related at this point...
  28. Jun 5, 2023 at 7:34 AM
    Reddog77
    Reddog77 New Member
    Zach
    I am having the same codes come up on my 2010 Sequoia. Did changing the transmission fluid ultimately fix the issues you were having?
  29. Jun 5, 2023 at 11:35 AM
    blackdemon_tt
    I only did the 4qt transmission fluid exchange and has been good since. I've since moved 400+ miles, made multiple trips to and from NorCal, even towed 2 cars and a few loaded up small 6x12 u-haul trailers. What I would advise you, since I was having other issues at the time, would be to check that bypass hose from the intake manifold to the throttle body. If that hose is cracked, you might as well replace it along with your drain and fill, you will require a throttle body gasket. The only 2 codes I've had since then were the C1201 code, maybe due to my front rotors seizing up and a performance D stuck off, don't remember the code. I do believe I need to replace the solenoid in the transmission. All transmission codes are off but has been shifting super smooth like butter. I do believe the rough shifts were due to that hose, cuz it was super rough 1st to 2nd, would cause hesitation, assuming the gaping hole was messing with the computer's pressure sensor and messing with the transmission's equalizing the pressure for shifting properly.
  30. Jun 5, 2023 at 8:43 PM
    Reddog77
    Reddog77 New Member
    Zach
    Got it. Thanks for that insight. I will change the transmission fluid and check that hose. Hopefully that fixes the issue for me. I appreciate the help.
