P0430 code
Discussion in '1st Gen Tundras (2000-2006)' started by romezter, Jul 16, 2020.
  1. Jul 16, 2020 at 9:27 PM
    romezter
    romezter [OP] New Member
    Roland
    Los Angeles, CA
    03 Tundra
    Plugged in my scanner and threw p0430 code bank 2 efficiency below threshold. Changed my o2 sensors downstream & upstream and still throws a code. Truck has 187k miles. Do I need a new cat ? I bought an exhaust manifold but haven’t installed it yet
  2. Jul 17, 2020 at 2:17 AM
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    Could need a new cat or a leak. Check leaks first as that's the easiest cheapest.
    romezter[OP] and revtune like this.
  3. Jul 17, 2020 at 5:27 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    Did you replace them with OEM denso sensors? These trucks don’t like certain non oem stuff.
  4. Jul 17, 2020 at 5:43 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Do you have an exhaust manifold leak? If you do, it's possible that the exhaust is scavenging air and not sending a correct value to the O2 sensor. You may have to fix the exhaust issue first, before moving further.
    romezter[QUOTED][OP] and revtune like this.
  5. Jul 17, 2020 at 11:18 AM
    romezter
    Roland
    Los Angeles, CA
    03 Tundra
    @revtune yeah I used Denso o2 sensors. @N84434 I’m suspecting an exhaust manifold leak I noticed the manifold was very black near the upstream o2 sensor and only in that area.
    revtune likes this.
