P0300, P0304, P0307
Discussion in '2nd Gen Tundras (2007-2013)' started by rxpnm1, Jul 20, 2020.
  1. Jul 20, 2020 at 12:05 PM
    rxpnm1
    rxpnm1 [OP] New Member
    Nelson
    none
    red salsa pearl toyota tundra 2008 5.7
    My 2008 tundra 5.7 has these 3 codes. I've replaced all of the ignition coils and spark plugs. I also replaced the 4th fuel injector valve. I also cleaned the maf sensor and throttle body. What can be the problem? Please let me know. Thank you!
  2. Jul 20, 2020 at 1:40 PM
    Rodion
    Rodion New Member
    Rodion
    2010 Tundra 4.6L V8 4x4
    Join this but have a feeling there won't be many comments... Personally I have P0300, P0303, P0305 (looks like Bank 1 only). New spark plugs, swapped coils but the issue didn't follow. Currently in a shop for diagnostic.
  3. Jul 20, 2020 at 2:38 PM
    docfnky
    docfnky New Member
    Valves need adjustment? Noticed any coolant loss?
  4. Jul 20, 2020 at 2:42 PM
    Rodion
    Rodion New Member
    Rodion
    Not sure... Coolant was changed recently (the truck also was purchased a month ago); no losses so far.
  5. Jul 20, 2020 at 2:45 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
  6. Jul 20, 2020 at 5:25 PM
    docfnky
    docfnky New Member
    Does it happen only when hot or always?
  7. Jul 20, 2020 at 10:15 PM
    Rodion
    Rodion New Member
    Rodion
    I couldn’t recognize those misfires. Dealer couldn’t catch it either while diagnosis. But the codes are there.
  8. Jul 20, 2020 at 10:17 PM
    Rodion
    Rodion New Member
    Rodion
    Going to check/do that. Thanks for the app advise. I have a wireless OBD reader.
  9. Jul 21, 2020 at 8:25 AM
    docfnky
    docfnky New Member
    I was working on another Tundra with the same code but will only misfire when hot. Turns out there was a small crack in the head and the coolant would put out the spark from the spark plug. The crack is so small it only expanded and leak when the engine was hot.
    Had another car where the valves were loose just enough to trigger the codes but never misfired.
    Hope the dealer is able to figure yours out soon.
    Rodion[QUOTED] likes this.
