P0157 + Performance Headers Troubleshoot
Discussion in '2.5 Gen Tundras (2014-2021)' started by 20Tun, Apr 15, 2021.
  1. Apr 15, 2021 at 7:12 AM
    20Tun
    20Tun [OP] New Member
    2020 Platinum
    First time Toyota owner here, so a whole new world for me (coming from GM). Please let me know if this post needs to be moved or is against the rules.
    I bought a used 2020 Platinum that the previous owner already did significant work to. That work includes performance headers, Borla exhaust (true duals), lift, wheels, and tires.
    Upon purchasing the vehicle, I received a P0420 code within 24 hours of driving off the lot with the truck. I've dealt with this code before on an older GM with performance exhaust. I purchased and installed catalytic spacers, similar to the ones found here: https://bit.ly/3mMuMMU . That cleared the code right away, as the imbalance in readings no longer appeared. This is a simple bolt-on application and can be easily removed.
    A few days later the CEL came on, and a P0157 code (Bank 2/Sensor 2) followed. The wiring appears to be fine, the harness doesn't appear to be damaged and I wasn't receiving this P0157 previously, which leads me to believe the sensor might be bad, though I have not popped a multimeter on the wiring, yet.
    All of this to ask two questions:
    1. Am I on the right track with my diagnosis?
    2. Assuming the sensor is NOT bad, is there a work-around for this? Is there such thing as a tuning chip/OBD plug to account for the performance headers and exhaust?
    The truck drives great and I can't see/hear/feel any performance issues, just the annoying CEL and not being able to use cruise control!
  2. Apr 15, 2021 at 9:04 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
  3. Apr 15, 2021 at 9:16 AM
    20Tun
    2020 Platinum
  4. Apr 15, 2021 at 9:21 AM
    JeffMac
    JeffMac 2 Words, 1 Finger
    Jeff
    South Florida
    2015 Black Tundra OVTUNE
    Suspension: Bilstein 6150 Front Max Setting CB Shim 2x Driver 1x Passenger Bilstein 5160 Rear CB +3 Shackles Firestone Airbags w/ Daystar Craddles Engine: OVTUNE - 87 w/ Torque Modifier SABM w/ K&N Filter TB Coolant Bypass Fumoto Drain Plug Wheels/Tires: ProComp Bandidos 0mm Offset Nitto Exo Grappler AWT 285/70/18 Exterior: TRD Pro Grille Spyder Headlights/Taillights Ecoological Bumpershellz LED everything Tinted windows Bakflip MX4 Tonneau Cover K-Source Tow Mirrors Interior: Pioneer AVH-W4500NEX Radio 2x 10” Pioneer Subwoofers 1200W Pioneer Mono Amp 2000W Pioneer 4 Channel Amp
    Probably need DAP Tuning to turn of the light.
  5. Apr 15, 2021 at 9:26 AM
    20Tun
    2020 Platinum
    Thank you - I'd assume it's these guys that you're referring to.
    Looks like they have remote tuning options - which is awesome, as I'm on the East Coast.
  6. Apr 15, 2021 at 9:27 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Exhaust leak some where...
  7. Apr 15, 2021 at 9:32 AM
    20Tun
    2020 Platinum
    Yeah - I saw that as a possible trigger, too. My thoughts were it's header related, but I could be off base. Unfortunately, my local shop can't get me in for a smoke test for two weeks, but I do plan on doing that prior to ordering new sensors or doing a tune. Hopefully, that would be the most cost-effective repair if it's minor.
    blackdemon_tt[QUOTED] likes this.
  8. Apr 15, 2021 at 10:03 AM
    RdKing
    RdKing Not A Roll Model
    Rich
    Eastern Seaboard
    2019 Tundra Platinum 3R3 / Barcelona Red
    Roadtunes By: Taylor's Audio/Tech12Volts Alma GA. JBL Complete System
    20Tun Congrats on the new truck and Welcome
    you can prob have another set of hands cover the tailpipes with shop rags to find exh leaks if there are any "faint/slight" leaks they will announce themselves
  9. Apr 15, 2021 at 10:05 AM
    JeffMac
    Jeff
    South Florida
    Yes those people. Definitely give Keith a call like stated above he’s big brain.
  10. Apr 15, 2021 at 11:40 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    What kind of headers? what cats did they use?
    I have stainless works long tubes, when using the cats they provided, I could never totally get rid of the codes and I've used at least 4 different variation of spacers, from simple 1" spacer to 90 spacers with drilled "grille" inserts in between, I was tired of keep playing with them so I had custom mid pipes made with OEM cats, if you have headers and it's leaking, you will hear it on these trucks.
