P0156
Discussion in '2.5 Gen Tundras (2014-2021)' started by Oz_zy, Feb 27, 2024.
  1. Feb 27, 2024 at 5:21 PM
    Oz_zy
    Oz_zy [OP] New Member
    2016 magnetic grey tundra tss off-road
    Morimoto headlights Morimoto xb led fog light Db custom tundra grill with led Spyder smoked led taillight
    So I got a engine code p0156
    Which is a malfunction of sensor 2 bank 2.
    Here's the situation:
    I installed jba lth and removed the 2 front cats. It's been running like this for 2 years the only codes I got at that time was for the missing cats and nothing else.
    I finally decided to get 3 inch mid pipes from dirtydeed with all 4 original cats, and installed stainlesswork exhaust. The codes for the missing cats went away, but now code P0156 pops up.
    What would cause this and how can I fix it. Local toyota charges $1,000 for all 4 sensors for parts only
    Joe333x likes this.
  2. Feb 27, 2024 at 5:27 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Denso part on Rock Auto, local auto parts store, Denso.com (I've ordered from them and got the wrong address on and they were able to correct it before it shipped out still made it on time, great customer service.), Stealership website +/-50% discount from the parts counter and pick it up at the counter or have it shipped to your door. Often its cheaper picking it up and you get face time with parts department. That's what I do.
    Oz_zy[OP] likes this.
  3. Feb 27, 2024 at 6:55 PM
    Oz_zy
    Cool, thanks for the info
    I went ahead and ordered all 4 sensors from sparks parts for 580. I still don't know what caused this, I'm still not certain if this will fix the issue.I can't find a clear answer on my search on Google. Hopefully someone will chime in and help with this.
  4. Feb 27, 2024 at 7:43 PM
    blackdemon_tt
    Shoulda just bought the 1 brother. Did you try pushing the pigtail back in?? sometimes they get fried, but if all you get is that code, odds are the rest are fine.
  5. Feb 28, 2024 at 5:29 AM
    Oz_zy
    Yes
    I disconnected the battery and waited 10 minutes before disconnecting the sensor. All the pins were fine and I made sure that it was plugged in properly. I drove it a couple of times with my scanner and it popped up again
  6. Feb 28, 2024 at 7:01 AM
    blackdemon_tt
    Ok, to me that's a sign that it's failed. I would just replace that 1 sensor and move on. I still have all 4 original ones from 07 or 06 when they were probably manufactured. My Celica has just 1 new pre cat o2 sensor since 02. I do believe if they fail with less than 100k miles they may be replaced under a warranty, not sure which one though, maybe emissions?
  7. Mar 1, 2024 at 4:00 PM
    Oz_zy
    They came in today
    This the old compared to the new one. I'm thinking of replacing all of them since I already paid for the 4?
  8. Mar 1, 2024 at 4:43 PM
    blackdemon_tt
    Thread is longer on the Toyota one... May be a clue. Choice is yours ultimately. Probably store the old ones that work in case you need them in the meantime, if you go through inspections.
  9. Nov 6, 2024 at 6:53 AM
    Oz_zy
    Well the code came back.
    The new ones lasted a couple thousand miles but the code came back.
  10. Nov 6, 2024 at 9:47 AM
    blackdemon_tt
    Here is a good way to troubleshoot them. since it may be a fuse, or wiring may be the issue.
    https://youtu.be/2lBhX54bDFU
