Oxygen sensors
Discussion in '2nd Gen Tundras (2007-2013)' started by Evanhawtrey, Dec 6, 2022.
  1. Dec 6, 2022 at 10:15 AM
    Evanhawtrey
    Evanhawtrey [OP] New Member
    Evan
    2012 tundra rock warrior
    I added bilstein struts up front instead of a leveling kit to raise it
    2012 tundra dbl cab 6.5’bed rock warrior .. stock exhaust .. are there 2 or 4 o2 sensors? Do you have to drop exhaust to change them ? Any tips? I’m throwing a code for 2 o2 sensors and I have 150k miles so I wanna just replace them all..Tia!
  2. Dec 6, 2022 at 11:57 AM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    IIRC there are 4 sensors, 2 in the front of the Cat and 2 in the back. As far as replacement. I do not recall where they are located. But I am sure others on here can chime in on that. BTW what Code are you getting? cause its not always a O2 sensor that needed changing when you get those codes.
    Also recommend using Original Denso O2 sensors (not fake ones from ebay and maybe Amazon) to fix them...
  3. Dec 6, 2022 at 1:09 PM
    Evanhawtrey
    Evan
    Po 172 po175 and it kinda rough starts.. it starts but it lags a bit compared to usual .. new map sensor .. new battery.. check engine light is on trac off is illuminated and 4 lo is flashing
  4. Dec 6, 2022 at 4:45 PM
    baraynavab
    Atlanta
    Did you look up the Long and Short Term fuel trims via obd2 or Techstream? Looking at those figures and then pushing a lean condition or rich condition on the engine may give you which O2 sensor is gone bad instead of you thinking of switching out all of them.
