Overheating
Discussion in '2nd Gen Tundras (2007-2013)' started by garyn, May 21, 2024.
  1. May 21, 2024 at 10:42 AM
    garyn
    garyn [OP] New Member
    Sequoia water boils in overflow, coolant temp gauge shows normal temp, all wiring at coolant temp sensor secure, changed thermostat and "Burped" system. Any common problems or ideas?
  2. May 21, 2024 at 11:35 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Did the cap come off complete? Including the "button" on the bottom of it?
  3. May 21, 2024 at 11:38 AM
    garyn
    No, cap did not come off, but the engine and coolant definitely hot
  4. May 21, 2024 at 11:51 AM
    bflooks
    bflooks New Member
    Metrowest MA
  5. Jun 3, 2024 at 9:34 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    If you're boiling, then it's not burped properly. You may need to go back and burp again. Unless your system is clogged by the radiator cap, but if its whole, I would go ahead and replace it now and burp the system with cap off and heater at full blast and defrost on as well.
